theone
(Dan Kessler)
December 25, 2018, 10:27pm
1
I am using HASSIO 0.84.6
I am trying to setup my logitech radio and have the following configuration under “media_player”:
- platform: squeezebox
host: 192.168.2.104
port: 9000
I can connect OK from a web browser.
The home-assistant log file shows:
2018-12-25 22:06:49 ERROR (MainThread) [homeassistant.components.media_player.squeezebox] Failed communicating with LMS: <class 'aiohttp.client_exceptions.ClientOSError'>
When I change the port to somthing else I get an expected Connection Error:
2018-12-25 22:20:12 ERROR (MainThread) [homeassistant.components.media_player.squeezebox] Failed communicating with LMS: <class 'aiohttp.client_exceptions.ClientConnectorError'>
What does the ClientOSError mean? and how do I solve it?
DrJeff
(DrJeff)
December 25, 2018, 11:53pm
2
Are you using a password and username? If so those need to be defined.
You can remove the port number that’s the default.
# Example configuration.yaml entry
media_player:
host: IP_ADDRESS
theone
(Dan Kessler)
December 26, 2018, 5:47am
3
No, no username and password used.
theone
(Dan Kessler)
January 9, 2019, 7:32pm
4
I am still having this issue.
Any other suggestions?
What does ClientOSError error mean?
gkron
February 19, 2019, 11:57pm
5
I’ve got the same thing spamming my log. Everything works though. In researching there is a hack to get it to stop but it’s a pain. Not sure why this hasn’t been fixed
hi,
is there any Squeezebox loosing connection to the LMS ?
Have a look at the LMS and check if all boxes are connected.
theone
(Dan Kessler)
February 20, 2019, 11:53am
7
All boxes are connected and playing fine.
I just can’t access from HASS
gkron
February 20, 2019, 3:17pm
8
My error is slightly different. Everything works though…
Failed communicating with LMS: class ‘aiohttp.client_exceptions.ServerDisconnectedError’
Are you still getting this error? I’ve found this happens if you power off a player.
