Logs riddled w/ errors
Looking for help to get my 6 year home assistant installation back on track. It is constantly losing connection/freezing/locking up and has tons of errors in the logs. I’ve tried to decipher the logs by even running them through an AI program but I just do not understand the jargon used to be able to find solutions. I’ve tried going back to backups but the problems still persist. I don’t really want to start from scratch, but sort of out of options. Anyone want to share my headache?
Can you clarify what you mean by “6 year”.
  1. Your version of Home Assistant is 6 years old and you’re attempting to upgrade directly to the latest version.
  2. You have been using Home Assistant for over 6 years and it’s running a recent version that you’re attempting to upgrade to the latest version
If it’s #1 then I advise you to start from scratch. The way things are done now are significantly different from 6 years ago.
#2 been using for 6 years currently on 12.2024.5
OK, that’s good news.
That suggests the root cause may be unrelated to the latest version.
Post at least one of the allegedly undecipherable Log messages.
Well the backups may have issues too as the same problems persists after going to a back up
2025-01-24 12:15:07.947 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/aircast/aarch64 with version 4.2.3
2025-01-24 12:15:07.950 INFO (MainThread) [supervisor.docker.interface] Attaching to mrlt8/wyze-bridge with version 2.10.3
2025-01-24 12:15:08.078 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/log-viewer/aarch64 with version 0.17.1
2025-01-24 12:15:08.756 INFO (MainThread) [supervisor.backups.manager] Found 38 backup files
2025-01-24 12:15:09.998 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/4662c172.tar: "filename './backup.json' not found"
2025-01-24 12:15:09.039 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/35a275a8.tar: "filename './backup.json' not found"
2025-01-24 12:15:09.121 INFO (MainThread) [supervisor.discovery] Loaded 2 messages
2025-01-24 12:15:09.122 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-01-24 12:15:09.122 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-01-24 12:15:09.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-01-24 12:15:09.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-01-24 12:15:09.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-01-24 12:15:09.124 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-01-24 12:15:09.125 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-01-24 12:15:09.125 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-01-24 12:15:09.126 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-24 12:15:09.128 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-01-24 12:15:09.129 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-01-24 12:15:09.130 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-24 12:15:09.133 INFO (MainThread) [__main__] Running Supervisor
2025-01-24 12:15:09.218 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as good
2025-01-24 12:15:09.259 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-01-24 12:15:09.287 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-01-24 12:15:09.288 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 4 add-ons
2025-01-24 12:15:09.432 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_samba application
2025-01-24 12:15:11.470 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 12.3.2
2025-01-24 12:15:11.637 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_5c53de3b_esphome application
2025-01-24 12:15:13.970 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/esphome/esphome-hassio with version 2024.12.1
2025-01-24 12:15:14.203 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_ssh application
2025-01-24 12:15:14.641 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_samba
2025-01-24 12:15:17.385 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-ssh with version 9.16.0
2025-01-24 12:15:17.667 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_aircast application
2025-01-24 12:15:21.788 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/aircast/aarch64 with version 4.2.3
2025-01-24 12:15:48.081 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2025-01-24 12:15:48.153 INFO (SyncWorker_4) [supervisor.docker.manager] Starting homeassistant
2025-01-24 12:15:49.029 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-01-24 12:16:18.747 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2025-01-24 12:16:18.748 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-24 12:16:19.613 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-01-24 12:16:19.677 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-01-24 12:17:11.715 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-01-24 12:17:11.738 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-01-24 12:17:11.765 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 3 add-ons
2025-01-24 12:17:12.372 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_cebe7a76_hassio_google_drive_backup application
2025-01-24 12:17:21.785 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/sabeechen/hassio-google-drive-backup-aarch64 with version 0.112.1
2025-01-24 12:17:22.339 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_7094bb28_docker_wyze_bridge application
2025-01-24 12:17:37.454 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on mrlt8/wyze-bridge with version 2.10.3
2025-01-24 12:17:38.525 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_logviewer application
2025-01-24 12:17:39.805 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:39.827 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:39.856 INFO (MainThread) [supervisor.api.middleware.security] /mounts access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:39.873 INFO (MainThread) [supervisor.api.middleware.security] /addons access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.117 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.211 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.245 INFO (MainThread) [supervisor.api.middleware.security] /backups/71e9f8dd/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.279 INFO (MainThread) [supervisor.api.middleware.security] /backups/d27d92e6/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.305 INFO (MainThread) [supervisor.api.middleware.security] /backups/d2abc8b2/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.455 INFO (MainThread) [supervisor.api.middleware.security] /backups/791802d3/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.542 INFO (MainThread) [supervisor.api.middleware.security] /backups/70fed6a4/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.570 INFO (MainThread) [supervisor.api.middleware.security] /backups/8dbed324/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.584 INFO (MainThread) [supervisor.api.middleware.security] /backups/8fd3777b/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.593 INFO (MainThread) [supervisor.api.middleware.security] /backups/900db860/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.603 INFO (MainThread) [supervisor.api.middleware.security] /backups/81e0f047/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.612 INFO (MainThread) [supervisor.api.middleware.security] /backups/a16e91c0/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.622 INFO (MainThread) [supervisor.api.middleware.security] /backups/366fa469/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.633 INFO (MainThread) [supervisor.api.middleware.security] /backups/573b043c/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.653 INFO (MainThread) [supervisor.api.middleware.security] /backups/5caddd56/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.664 INFO (MainThread) [supervisor.api.middleware.security] /backups/bd0f74b9/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.678 INFO (MainThread) [supervisor.api.middleware.security] /backups/aad7bfc8/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.692 INFO (MainThread) [supervisor.api.middleware.security] /backups/8312d485/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.715 INFO (MainThread) [supervisor.api.middleware.security] /backups/22af45ac/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.724 INFO (MainThread) [supervisor.api.middleware.security] /backups/72ab1b56/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.737 INFO (MainThread) [supervisor.api.middleware.security] /backups/73afa177/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.751 INFO (MainThread) [supervisor.api.middleware.security] /backups/b683d56d/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.765 INFO (MainThread) [supervisor.api.middleware.security] /backups/62c6f1e3/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.779 INFO (MainThread) [supervisor.api.middleware.security] /backups/c72b58a0/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.855 INFO (MainThread) [supervisor.api.middleware.security] /backups/b681e358/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.868 INFO (MainThread) [supervisor.api.middleware.security] /backups/1ca4efbb/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.879 INFO (MainThread) [supervisor.api.middleware.security] /backups/9a482aa6/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.896 INFO (MainThread) [supervisor.api.middleware.security] /backups/58e320eb/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.910 INFO (MainThread) [supervisor.api.middleware.security] /backups/3ae4a178/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.925 INFO (MainThread) [supervisor.api.middleware.security] /backups/ff840c94/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.945 INFO (MainThread) [supervisor.api.middleware.security] /backups/ba8c0f28/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.967 INFO (MainThread) [supervisor.api.middleware.security] /backups/4b98c257/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:41.982 INFO (MainThread) [supervisor.api.middleware.security] /backups/a69c31e1/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:42.027 INFO (MainThread) [supervisor.api.middleware.security] /backups/4c1eff28/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:42.046 INFO (MainThread) [supervisor.api.middleware.security] /backups/6bea9266/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:42.067 INFO (MainThread) [supervisor.api.middleware.security] /backups/664d1c27/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:42.089 INFO (MainThread) [supervisor.api.middleware.security] /backups/a487abaa/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:17:42.114 INFO (MainThread) [supervisor.api.middleware.security] /backups/4a9d4471/info access from cebe7a76_hassio_google_drive_backup
2025-01-24 12:18:35.258 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from 7094bb28_docker_wyze_bridge
2025-01-24 12:19:07.303 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:19:34.487 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/log-viewer/aarch64 with version 0.17.1
2025-01-24 12:19:43.011 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-01-24 12:19:43.272 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-01-24 12:19:43.299 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-01-24 12:19:43.958 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-01-24 12:19:44.511 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-01-24 12:19:44.516 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-01-24 12:20:02.537 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: Timeout
2025-01-24 12:20:21.172 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:20:21.612 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:20:21.615 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:20:21.618 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:20:21.620 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:20:21.927 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-01-24 12:20:21.931 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-01-24 12:20:22.997 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-01-24 12:20:40.821 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
2025-01-24 12:20:41.906 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-01-24 12:20:41.021 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-01-24 12:20:41.023 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
2025-01-24 12:20:41.024 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-01-24 12:20:41.026 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
2025-01-24 12:20:41.027 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-01-24 12:20:41.029 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-01-24 12:20:41.080 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-01-24 12:20:41.081 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-01-24 12:20:41.083 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-01-24 12:20:41.086 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-01-24 12:20:41.411 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Connector is closed.
2025-01-24 12:20:42.178 INFO (MainThread) [supervisor.host.services] Updating service information
2025-01-24 12:20:43.589 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-01-24 12:21:20.416 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:21:25.881 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:21:28.624 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:21:34.699 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-01-24 12:21:42.764 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-01-24 12:22:22.809 ERROR (MainThread) [supervisor.host.logs] Could not get a list of boot IDs from systemd-journal-gatewayd
2025-01-24 12:22:31.165 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-01-24 12:22:32.590 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-01-24 12:22:32.592 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-01-24 12:24:18.783 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:24:53.187 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2025-01-24 12:24:53.854 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missed an Home Assistant Core API response.
