Long term statistic on water measure counter
I have problems getting long term statistics from a water measure counter.
Here is my configuration:
I build up a ESPHome node with a water pulse meter (each litre 1 pulse) that gives me actual flow rate (litres/min) and actual counter (litres). Actual counter restarts at 0 each time the ESP32 reboots, so I created 3 utility_meter entities (for daily, monthly and yearly total).
Everithing is working as expected.
As I understand each sensor should create long term statistic, but I can only see the total counter going up if I put in the statistic graph; I instead wuold like to have a bar graph with consumpion data for each day/month.
Here is the sensor config in ESPHome:
  - platform: pulse_counter
    pin:
      number: 33
      mode:
        input: true
        pullup: true
    unit_of_measurement: "l/min"
    update_interval: 6s
    filters:
      - debounce: 150ms
      - sliding_window_moving_average:
          window_size: 10
          send_every: 1
    total:
      unit_of_measurement: 'litri'
      filters:
        - multiply: 1.000
and the utility meters config
utility_meter:
  acqua_consumata_giorno:
    source: sensor.consumo_acqua
    name: Consumo acqua odierno
    cycle: daily
  acqua_consumata_mese:
    name: Consumo acqua mensile
    cycle: monthly
  acqua_consumata_anno:
    name: Consumo acqua annuale
    cycle: yearly
Card:
chart_type: bar
period: day
days_to_show: 30
type: statistics-graph
entities:
  - sensor.utm_l1
stat_types:
  - state
This is a hidden feature.
It may change or be removed in future
Thank you, for daily graph seems working perfectly.
For month I changed period to month and days_to_show to 365.
Thank you for prompt response!
