Hi everyone,
I’ve been experimenting with the HLK-LD2450 mmWave radar sensor connected to an ESP32, and I’m currently using this firmware:
https://github.com/53l3cu5/ESP32_LD2450
It basically works, but I’m running into a few issues:
- The project is no longer maintained.
- The firmware is too large, so I can’t add my additional sensors (I’m using AHT20 + BMP280 and BH1750) — it quickly runs out of space or becomes unstable.
- I’d like something more lightweight or modern that still integrates well with Home Assistant or ESPHome.
My goal:
Find a more efficient firmware or example code for the LD2450 + ESP32, ideally one that allows adding I²C sensors (AHT20/BMP280/BH1750) and can still handle the radar data reliably.
So I’d really appreciate your advice:
- Which firmware or ESPHome configuration works best for you with the LD2450?
- Has anyone successfully combined the radar with environmental sensors?
- Any known stable forks or projects that are still active?
Thanks a lot for any suggestions or shared examples!
