Looking for paid Home Assistant consultant – NYC, HVAC integration
Looking to hire someone in New York City for a half-day paid job setting up Home Assistant to control a Daikin VRV system via CoolMaster, using room temperature sensors to offset setpoints per zone.
Specifics:
∙ CoolMaster already installed and working
∙ 5 zones/rooms
∙ Aqara temperature sensors (to be purchased) + Apple TV as Thread border router
∙ Goal: HA automation that reads each room sensor and adjusts CoolMaster setpoint to compensate for the delta between air handler temp and actual room temp
∙ Need physical setup (HA Green hardware, Aqara hub, sensor placement) plus the automation scripting
Not looking to replace any existing infrastructure — everything stays, HA is additive only. Straightforward scoped job, happy to pay well for the right person.
Manhattan. Please reply here or DM if you have CoolMaster + VRV experience specifically.
Giggles on specific time attribution. Just downloading software updates on the green may take longer!
Forgive me
And when ir reboots 2 weeks from then and a message come up that Aqara gets confused, or in 6 months when coolmaster changes their API and the jailbroken version in HA core that someone came up with no longer works, what are you going to do?
No risk it happens product exists since nearly 15 years at least and works like at first day :wink: I have quite few ones at customers that run since ages without any problems !
