I’m looking for a solar + LTE (4G/5G) camera that supports RTSP for use with Home Assistant / Frigate.
My use case:
currently off-grid → needs solar + LTE
motion detection is enough for now
later it will have wired internet, and I’d switch to LAN and use continuous RTSP streaming in Frigate
The problem:
I only keep finding cloud-locked LTE/solar cameras that work only through the manufacturer’s app and don’t expose RTSP/ONVIF.
I did find one LTE camera with an RJ45 port, but:
RJ45 alone doesn’t guarantee it isn’t cloud-dependent
it has no solar option
powering it from solar seems complicated (it uses internal 18650 cells but requires a 12V 2A input)
Basically I’m trying to avoid buying a device that becomes useless if the vendor cloud disappears, and I’d like something that can work locally later over LAN with RTSP.
Does anyone know a model (or setup) that fits this use case?
Can you not use solar camera and separately connect them to cellular
Look at Ubiquiti nano station AC loco. This is backhaul WiFi ap with range of miles.
I would connect camera and AP to switch and power locally by solar. This would connect to central AP(there is Ubiquiti model with external antenna that is (I forget term) circular antenna . I would have cellular uplink there. You may also just have camera and cellular ap local
There are cellular modules for arduino so building a unit using esp32 is an option
