Looking for zigbee 2 Gangs switch module with Neutral
Hello!
i’am looking for zigbee 2 Gangs switch module with Neutral. And i know that the a lot of modules has a similar onnoying problem - if you press both physical switches same time - it’s randomly turns on only one device. Is there any modules which has no this bug?
PS - i wanto to put module behind existing stupid 2 gang switch, so no gangs is requered, only switch module
Which country are you? What voltage? How much amps you need to switch?
230V 50Hz Europe → Zigbee Aeotec Pico Duo Switch
or: Zigbee – Vesternet
230V 50Hz Europe Yes. 5A is ok, even less
You devices looks interesting, will try it and hope there is no such bug with two gangs :slight_smile:
Use two single gang modules if space permits it?
there is no space for two single modules.
Vesternet Zigbee 2 Channel Switch
Aqara Dual Relay Module T2 – Vesternet
These might also work.
