[Looking For] ZigBee wall switch with mechanical push button
Hi All,
Looking for simple looking Zigbee wall switch, which imitates standard mechanical push switch with normal press distance ~5mm, not just a ‘click’.
EU socket, 230V.
There is fine looking MOES and BSEED switches, but they are all ‘click’, not real ‘push’:
Other requirements:
1,2-gang switches with1,2,3-gang frames, + power sockets.
Should support direct binding (stairs mode), long press, double click.
Led with option to disable/invert.
Ideally with support of relay (de-touched) mode.
And super ideally fits with standard 55mm frame, which is very common.
Nobody? :slight_smile: First who will make such switch will become a billionaire ))
Use standard (dump) switch and put a Shelly (mini) behind?
I have some now, but it’s not the best option - no led, wiring is a pain as wall boxes at some places doesn’t fit it all well.
