I have an automation that turns on the lights when frigate detects a person. I am trying to loop until the frigate event that triggered the automation sends an ‘end’ event or the loop times out. I tried many different ways, but the loop keeps executing even after the event end message is received. current code:
event_ended variable is set to false before loop starts
id is captured from original frigate event that triggered the automation
alias: Loop until end event is received or timeout happens.
repeat:
sequence:
- alias: Wait for an MQTT message or loop timeout
wait_for_trigger:
- alias: MQTT message with matching event ID
topic: frigate/events
value_template: >-
{{ wait.trigger.payload_json['after']['id']|string() == id|string()
and wait.trigger.payload_json['type']|string() == 'end' }}
trigger: mqtt
continue_on_timeout: true
timeout:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- variables:
event_ended: >-
{% if event_ended != true %}
{% if wait.trigger is defined and wait.trigger.payload_json is defined %}
{{ wait.trigger.payload_json['after']['id']|string() == id|string() and wait.trigger.payload_json['type']|string() == 'end' }}
{% else %}
false
{% endif %}
{% endif %}
until:
- alias: Event end is received for triggering event that started automation
condition: template
value_template: "{{ event_ended != false }}"
I had logging in the loop and event_ended is correctly set to true when id matches and event type = ‘end’ however loop is not exited.
Another issue is that MQTT triggers on any event id and message type. this should not matter since values are checked when event_ended is set, but ideally this loop would only fire once then exit.
Here’s an example log where iteration 7 evaluated as true, but it kept running iteration 8 & 9
Iteration 7
Executed: March 20, 2025 at 3:19:56 AM
Result:
params:
domain: logbook
service: log
service_data:
domain: automation
entity_id: automation.frigate_notification_mqtt_front_door_lights
message: >-
person was detected on Front Door camera - repeat loop iteration=7
Event ID from automation trigger= 1742455179.136992-xmkwvn New event ID
is defined=
original event id= 1742455179.136992-xmkwvn
after event id=>>>1742455179.136992-xmkwvn<<<
original variable type= update
payload_json type= ------>end<------
before time=--->1742455180.045057<---
after time=--->1742455191.272018<---
event_ended=True
target: {}
running_script: false
Iteration 8
Executed: March 20, 2025 at 3:19:57 AM
Result:
params:
domain: logbook
service: log
service_data:
domain: automation
message: >-
person was detected on Front Door camera - repeat loop iteration=8
is defined=
after event id=>>>1742455180.368356-ty48sp<<<
before time=--->1742455190.962753<---
after time=--->1742455191.965489<---
event_ended=False
target: {}
