Lora MQTT Bridge
I am currently trying to build a Lora-MQTT bridge between two raspberrys.
(well initially two ESP32 were planned, but dropped because of additional features needed)
see JPTs-Homeassist-Addons/LoraMqttBridge at main · JPT77/JPTs-Homeassist-Addons · GitHub
I want to use the same code in the HA-App@HAOS and on RaspiOS@Z2W.
I already got a proof of concept that validates hardware, libraries etc on RaspiOS.
Now I try to make it work in HA.
I use the LoraRF Python library.
Problem is: LoraRF uses RPi.GPIO which is not available on HA.
My Solution was to use the drop in replacement called rpi-lgpio
While I was able to build it during app installation, it is missing the lgpio binary.
This does not seem to be available through apk?
Should I try building liblgpio myself?
Or is there another way?
thank you very much
Type this into a search engine. Lots of things to pick from here starting with the HA GPIO integration…
site:home-assistant.io gpio app add-on
I solved it after a lot of trial and error.
This is my Dockerfile
# cannot install adafruit-lgpio on Python 3.12
FROM ghcr.io/home-assistant/aarch64-base-python:3.13-alpine3.22
WORKDIR /app
# needed so it opens correct devices?
ENV RPI_LGPIO_REVISION=e04171
RUN apk add --no-cache \
      python3 \
      py3-pip \
      linux-headers \
      gcc \
      musl-dev \
      swig \
      libgpiod
# this lgpio implementation also delivers the binary which lgpio doesn't
RUN python3 -m pip install --no-cache-dir \
      adafruit-lgpio
# do not install dependencies automatically
RUN python3 -m pip install --no-cache-dir --break-system-packages \
      rpi-lgpio --no-deps
# install LoRaRF dependencies manually
      paho-mqtt \
      PyYAML \
      gpiod \
      spidev
# do not install dependencies automatically so RPi.GPIO isn't installed
      --no-deps LoRaRF
on RaspiOS i simply install dependencies like this
pip install LoRaRF paho-mqtt PyYAML spidev gpiod
