LoRaWAN actuator for irrigation valve validated on Home Assistant
For experts proficient in HASS, LoRaWAN, and MQTT, STREGA has just validated its LoRaWAN irrigation valve actuators with Home Assistant.
The actuator can operate wirelessly over several kilometers/miles with a battery life of 7+ years (even with daily use). Bidirectional communication between the actuator and the LNS (tests performed on TTN) is made via MQTT. The device is available from the manufacturer for €150.00. A limited number are available for testing and evaluation. The documentation will be improved in the future. Datasheet available at: https://www.stregauniverse.com/datasheet/SV2-LoRaWAN-Actuator-for-Irrigation-Valve-Home-Assistant.pdf.
@Dominicd are you affiliated with this company? Is this an ad?
+1 and website shows a lot of technical infos but not address of company or phone number, looks like a scam or a vaporware :smiley:
No scam, guys, this is our company and located in Belgium. Long time HA user myself so experienced the device home using MQTT. Works great.
It is a working solution for long range wireless irrigation where Home Assistant provides real smart irrigation. You can consider my post as an ad...or a new solution that works.
You can contact me any time for further info.
Phone number and email available on each page !
