Truenas Scale with
Home Assistant 2023.8.2_20.0.3
ESPHome 2023.7.1_15.0.1
BME-280 (Sumklin) Temp/Humidity Sensor
ESP8266 ESP12 NodeMcu Mini D1 Module for WeMos Lua 4M
Wired:
D1 - BME280
3v3 - VIN
G - Gnd
D1 - SCL
D2 - SDA
I see 3.85 volts across VIN and Gnd on the BME280
In the web interface for ESPHome I do the initial installation. I then go do the ESPHome dashboard to configure the BME-280 sensor. I have access to the built-in web interface of the D1 module and it shows up as esphome-web-e3ceb6 at 192.168.1.32.
The installation appears to go OK, but when it reboots I lose wi-fi connectivity.
I have tried adding a manual ip with the same result.
When I go back and do an ‘initial setup’ from the web ESPHome interface I can access from Home Assistant - but nothing shows up for the sensor.
I created a .bin update file with no errors, and uploaded that - but same results; wifi disconnects after successful upgrade.
Using the default template that comes up for the esp8266 here’s my modified yaml:
esphome:
friendly_name: esphome-web-e3ceb6
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "vsTQhYHqBNibivTHqQHentys/nP77frKbwBLO0FHk7U="
ota:
password: "951771b3b9611b138b9c9e32d520755a"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.32
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Esphome-Web-E3Ceb6"
password: "7JrJRfgPfDXK"
captive_portal:
i2c:
sda: D2
scl: D1
scan: True
# Example configuration entry
- platform: bme280
temperature:
name: "DC Temperature"
oversampling: 16x
pressure:
name: "DC Pressure"
humidity:
name: "DC Humidity"
address: 0x77
update_interval: 60s
type or paste code here
INFO ESPHome 2023.7.1
INFO Reading configuration /config/esphome-web-e3ceb6.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-e3ceb6 (board: d1_mini; framework: arduino; platform: platformio/[email protected])
Library Manager: Installing esphome/ESPAsyncTCP-esphome @ 1.2.3
INFO Installing esphome/ESPAsyncTCP-esphome @ 1.2.3
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing ottowinter/ESPAsyncTCP-esphome
INFO Installing ottowinter/ESPAsyncTCP-esphome
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|-- Wire @ 1.0
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/bme280/bme280.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/esp8266/core.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/esp8266/gpio.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/esp8266/preferences.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/i2c/i2c.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/i2c/i2c_bus_arduino.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/i2c/i2c_bus_esp_idf.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/sensor/automation.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/sensor/filter.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/sensor/sensor.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/application.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/color.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/component.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/controller.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/log.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/time.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/esphome/core/util.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/src/main.cpp.o
Generating LD script .pioenvs/esphome-web-e3ceb6/ld/local.eagle.app.v6.common.ld
Compiling .pioenvs/esphome-web-e3ceb6/lib309/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib309/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib309/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib309/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib309/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib181/Hash/Hash.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFi.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/lib181/libHash.a
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/WiFiClient.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/lib309/libESPAsyncTCP-esphome.a
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb1/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib6dd/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib070/DNSServer/DNSServer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/ESP8266mDNS.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/LEAmDNS.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/LEAmDNS_Control.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/libfb1/libESP8266WiFi.a
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/lib070/libDNSServer.a
Compiling .pioenvs/esphome-web-e3ceb6/libfb2/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/sodium/codecs.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/sodium/core.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/sodium/runtime.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib545/libsodium/sodium/utils.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/sodium/dh-curve25519.c.o
Archiving .pioenvs/esphome-web-e3ceb6/lib6dd/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/errors.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/internal.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/names.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/patterns.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/randstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/signstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib96b/noise-c/protocol/util.c.o
Compiling .pioenvs/esphome-web-e3ceb6/lib953/Wire/Wire.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/libFrameworkArduinoVariant.a
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Crypto.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Esp-frag.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Esp-version.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/FS.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/HardwareSerial.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/libfb2/libESP8266mDNS.a
Archiving .pioenvs/esphome-web-e3ceb6/lib96b/libnoise-c.a
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/LwipDhcpServer.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/lib953/libWire.a
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/LwipIntf.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/StreamSend.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/Updater.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/aes_unwrap.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/cont.S.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Archiving .pioenvs/esphome-web-e3ceb6/lib545/libsodium.a
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/exc-sethandler.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/mmu_iram.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/stdlib_noniso.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/time.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/esphome-web-e3ceb6/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving .pioenvs/esphome-web-e3ceb6/libFrameworkArduino.a
Linking .pioenvs/esphome-web-e3ceb6/firmware.elf
RAM: [==== ] 42.2% (used 34596 bytes from 81920 bytes)
Flash: [===== ] 47.7% (used 498061 bytes from 1044464 bytes)
Building .pioenvs/esphome-web-e3ceb6/firmware.bin
esp8266_copy_factory_bin([".pioenvs/esphome-web-e3ceb6/firmware.bin"], [".pioenvs/esphome-web-e3ceb6/firmware.elf"])
========================= [SUCCESS] Took 36.45 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.1.32
INFO Uploading /config/.esphome/build/esphome-web-e3ceb6/.pioenvs/esphome-web-e3ceb6/firmware.bin (502208 bytes)
INFO Compressed to 352072 bytes
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.32 using esphome API
