Lost connection to Hassio
After having problems for several days trying to upgrade to v0.64 I tried to restart hassio. But after trying to restart, I cannot connect to it any more! I can see on my router that hassio is connected to the network, and has an IP adress, and I get response when pinging this IP. The web interface will not come up however, and samba share does not work. I also tried to connect to the pi with putty, but it does not work. What can I do?
faulty sd-card? power supply?
Only thing to do is take out the sdcard and put it in a pc/mac to see if you can read the config dirs so you can edit the files there, since it’s likely a breaking change/config error.
The problem was that the databasefile was to big somehow… It was around 6gb and the sd card was full. After a lot of hassle I managed to mount the SD card on a virtual linux computer and deleted the DB file. When I put the card into the raspberry everything worked fine :slight_smile:
