Recently I’ve lost control of my z-wave devices from HA. If I toggle a switch on/off I can see the state update in HA. But if I try to toggle the switch from HA nothing happens.
Mainly I see this because none of my automations work any longer.
look at TX/RX under Device info >> 3dot next to configure >> statistics
Look for dropped commands and hi RTT.
If you have battery devices in this devices route or this is battery device maybe replace batteries.
You can look at “rebuild routes” in same area mention above for that one device but I would do that after confirm other items above. rebuilding routes should be used extremely sparingly and only after you check everthing else. Doing this can create issues for other devices especially if you do this to a lot of devices at once.
since the problem is recent it must have good path back to controller so maybe route changed or maybe some temporary inteference / issue.
Yes. Looks like commmunication zwavejs to controller keeps dropping
This will cause issues with all devices on network and has nothing to due with interference
If problems started after update, consider rolling back and verifying things stabilize. If so, report that.
From whimch version to which?
If all devices have problems this is likely the cause.
I thought only the one device was having issues?
Looking at the stats you posted it looks rock solid and since it connect direct to controller the likely cause is
controller problem if other device effected
Device problem if only the one device effected
I use zwavejsui v 9.31.0. Released March 2025
Try that.
Current latest version is 10.1.3
You will want to backup your /usr/src/app/store folder and run new container from the backup folder, not original, in case issues occur. You don’t wanna lose this data
