2020-01-09 22:33:07.749 Detail, Node010, Queuing (Controller) Request Node Neighbor Update
2020-01-09 22:33:07.749 Detail, Node010, Queuing (Controller) Delete All Return Routes
2020-01-09 22:33:07.749 Detail, Node010, Queuing (Controller) Assign Return Route
2020-01-09 22:33:07.750 Info, Requesting Neighbor Update for node 10
2020-01-09 22:33:07.750 Detail, Node010, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=10): 0x01, 0x05, 0x00, 0x48, 0x0a, 0x1e, 0xa6
2020-01-09 22:33:07.750 Detail, Notification: ControllerCommand - Starting
2020-01-09 22:33:07.752 Error, Node010, ERROR: Dropping command because node is presumed dead
2020-01-09 22:33:07.752 Detail, Node010, Removing current message
2020-01-09 22:33:07.753 Detail, Notification: ControllerCommand - Error - Failed
2020-01-09 22:33:07.756 Info, Deleting all return routes from node 10
2020-01-09 22:33:07.756 Detail, Node010, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=10): 0x01, 0x05, 0x00, 0x47, 0x0a, 0x1f, 0xa8
2020-01-09 22:33:07.756 Detail, Notification: ControllerCommand - Starting
2020-01-09 22:33:07.759 Error, Node010, ERROR: Dropping command because node is presumed dead
2020-01-09 22:33:07.759 Detail, Node010, Removing current message
2020-01-09 22:33:07.760 Detail, Notification: ControllerCommand - Error - Failed
2020-01-09 22:33:07.760 Info, Assigning return route from node 10 to node 1
2020-01-09 22:33:07.760 Detail, Node010, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=10): 0x01, 0x06, 0x00, 0x46, 0x0a, 0x01, 0x20, 0x94
2020-01-09 22:33:07.761 Detail, Notification: ControllerCommand - Starting
2020-01-09 22:33:07.762 Error, Node010, ERROR: Dropping command because node is presumed dead
2020-01-09 22:33:07.762 Detail, Node010, Removing current message
2020-01-09 22:33:07.762 Detail, Notification: ControllerCommand - Error - Failed
2020-01-09 22:33:44.335 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 3 - False
2020-01-09 22:33:44.335 Info, Node010, SwitchBinary::Set - Setting node 10 to Off
2020-01-09 22:33:44.335 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Set (Node=10): 0x01, 0x0e, 0x00, 0x13, 0x0a, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x21, 0xa1
2020-01-09 22:33:44.335 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=10): 0x01, 0x0d, 0x00, 0x13, 0x0a, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x22, 0xa3
2020-01-09 22:33:44.336 Error, Node010, ERROR: Dropping command because node is presumed dead
2020-01-09 22:33:44.336 Detail, Node010, Removing current message
2020-01-09 22:33:49.408 Info, mgr, Refreshing node 10: COMMAND_CLASS_METER index = 8 instance = 3 (to confirm a reported change)
2020-01-09 22:33:49.408 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=3): MeterCmd_Get (Node=10): 0x01, 0x0e, 0x00, 0x13, 0x0a, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x32, 0x01, 0x00, 0x25, 0x23, 0xb4
2020-01-09 22:33:49.408 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=3): MeterCmd_Get (Node=10): 0x01, 0x0e, 0x00, 0x13, 0x0a, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x32, 0x01, 0x10, 0x25, 0x24, 0xa3
2020-01-09 22:33:49.408 Info, mgr, Refreshing node 10: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 3 (to confirm a reported change)
2020-01-09 22:33:49.409 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=10): 0x01, 0x0d, 0x00, 0x13, 0x0a, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x25, 0xa4
2020-01-09 22:33:49.409 Error, Node010, ERROR: Dropping command because node is presumed dead
2020-01-09 22:33:49.409 Detail, Node010, Removing current message
