I’ve just upgraded to Home Assistant OS 8.5 and Core 2022.9.7. When I logged on again the connection to Hive had failed to set up. Below is the log:
Logger: homeassistant.config_entries
Source: components/hive/__init__.py:89
First occurred: 14:46:27 (1 occurrences)
Last logged: 14:46:27
Error setting up entry [email protected] for hive
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 357, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/hive/__init__.py", line 89, in async_setup_entry
devices = await hive.session.startSession(hive_config)
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 494, in startSession
await self.getDevices("No_ID")
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 417, in getDevices
await self.hiveRefreshTokens()
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 304, in hiveRefreshTokens
result = await self.auth.refresh_token(
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/api/hive_auth_async.py", line 548, in refresh_token
result = await self.loop.run_in_executor(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 391, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 691, in _make_api_call
request_dict = self._convert_to_request_dict(
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 739, in _convert_to_request_dict
request_dict = self._serializer.serialize_to_request(
File "/usr/local/lib/python3.10/site-packages/botocore/validate.py", line 360, in serialize_to_request
raise ParamValidationError(report=report.generate_report())
botocore.exceptions.ParamValidationError: Parameter validation failed:
Invalid type for parameter AuthParameters, value: ({'REFRESH_TOKEN': 'eyJjdHkiOiJKV1QiLCJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiUlNBLU9BRVAifQ.UJq_fv2Pth0MxIuXOlr13WxJSWeagJcabwqTe5Klj3mxGQ9U1m3kD7sWWKrX30xNjJKL3igmImZs_3MCLfE2jdI87g_TMU_dINUTWoASlbcuAe8mln-uqmVQSjTpV-oMtMwVJi1nUuO-JSgTmnyy5HbTa2Cu1dW14MRBUQU8uyiYq6r4s4IaX8mi4ysD1zbUBR2Z1pE9FyrJmYQDzxntp5mz_r6J0oxeeb_y0pjrxUNPokxi5bwxtO5APvCQQGVOPcF4m8r-GrtErYl785zkJQU_E2SSmcNj3jRMrSf3u0nFWscs_vzeDlLh481oqWSGAlOpFcXAzUCYs-5rH-1ydw.yNL2xGJN-oEEi1py.MTPlg5Rdev3oQQHzHAMuXP2KuBxyGKKyNuUM9YnAlXsDjjNR0C9u9iBS0y8a-dcnUljSN72Bk8mmFJH6HE1ULOkKWKVTUcYp9FkM2qmJI0x5Qd6ZgTGhrNwy879vFku4YafBrBJlDE0V7Pdf7Cq30i6qqgj5DdmcwvRz-MtN4RfG9rT8IUpyF0u0XX4cTTjlrOChRnNI5i3_h8q5Y3me2t2uLa1goruDRU32QLbAH4xOeRSba0sSCbwCZIv2cl5DVhWys17fh7S2JZ2JtoLGRkd2OyuHtHo4RwHFsUhHY1iXcTfS7o8J1aAblaVUNzAUNXC-_Bz6ekq4MX55V9yle6GSIjI1FHkWJmUA1VIK0i8XolGK2kkOG2NciltP-n4y9qgeA0_IT8O_NY_UiTgrRYmrUyL0m27i8Pxb-BmhxMDdx2NUreB8hLAXo9i94iWo1r2GFasMSyRMwmT3jyxX2QMXqq4n_6TjidjqlU5qskZsswYh95dcRgjg-B1EBAtyj7lgl9d4brv3rdrK1QjuIJoA3oBpAN8G5rGZQ1YNZhmvoasBzRguSOnXuNoe9R-djPG-I2GFNORM9WvuwU3j0cEQFQKOsL-M_xiYOK7_YE8bih6omIHPUl50WqJnfQyNX_VsMnOg_xoOK74Vh5Us4aiHdQ6k9HNFRW-he33peuJ0BB6kHBVkpo809iA73tiK2BYhYbIgrlHo7VvHL7sukuZDKQIeyj0tAgj7uzSNncqFt2tRHiQ_tqmP5Cc51S_N02aADgmQB9wiUjCoE_oy6p-r9sfGULniO_w6DaS6MGIL1Un2uge6Ea2r_4gQ4SSw7Dt16Hr8aMOyz5qMUzl4IYrYViBMPHJ5mqKBUKn5xrycHGPgHYIBpY8Gx1uZjOwO0LA-bfzGnWByTnK_kySsoCby_6TAN-HfuzvdadyFt_0QNtm8TkaJb-y-F99wUbWgmeiyTpKdaLKG_FzvW30L1URWegltGiy3JitDcghs0ZOJN-JodACKfku0v046tyA2bkv98Cijz-3LNOmLmchr-Z1J2tBHWJ5bAjEhuQeh25KLQbSdYMkWpplpyaaQlJGs0X-svmFhXNSrZnztAwoFxVw9yzspdl1FqgWtrq5CGBfWpBRtxmsoXNTNGo6c9-c63J-w1ecOr2YLDZBJNn_wysXcP0oFETeTVCK3YFOv7VUyV1UnHfSE39bsCh9ygZmZcumR3QPWRHN-zCXT6MLNn5tzX3UVXAw0unrSY1TqM_I8IpupxAgtP3TK2oxdhfrioeFL6nlsddPfjWWBw6H4O8B6k5iCY2HaFhXTGhBDTM_5_uc4VJt7IEQtFCc.UOK2uwA9wwaG4sCHEu1VYg'},), type: <class 'tuple'>, valid types: <class 'dict'>
