I am running:
- Home Assistant OS 14.2 with Home Assistant Core 2025.3.3
- Home Assistant Companion App 2025.2
- Home Assistant Connect ZBT-1 (configured for Thread)
- Open Thread Border Router (configured for the ZBT-1 mentioned above)
- Thread integration (with the Open Thread Border Routing mentioned above being the preferred network)
- Matter integration showing 7 Matter devices connected through the Matter-over-Thread network and 9 devices connected though a Matter-over-Wifi network (2.4 GHz)
I just wanted to add a new Matter-over-Wifi devices using the “Add matter device” functionality of the HA Companion App as I did many times before. Surprisingly, this time I received an error message (in German) basically saying “Failed to save Thread network credentials. Error: Thread network credentials does (sic!) not match with any of the active thread networks around.”
I checked at “Companion App → Debugging → Thread” in my HA Companion App, and indeed there were no Thread credentials stored anymore. I tried to “send credentials to phone” from the Thread integration but get the said error message.
This leads me to the following questions of which I hope someone of you can help me with:
- Where did my Thread credentials go and what can I do to make HA find them again?
- This question might be unrelated but here we go: The device I wanted to add was a Matter-over-Wifi device. Hence, I wasn’t planning to add something to the Thread network anyway. I could skip the error message but wasn’t eventually able to add the Matter-over-Wifi device. The Thread credentials are only needed for Matter-over-Thread devices, right?
