Hi
I'm desperate about installing with esphome this Electraw Crowpanel
24h with Gemini and Chat and ..nothing wifi ok but no display. dozens of versions flashed and always 'black' or various backgrounds colors with vertical thin (about 1cm central area)
every try is game over
Does anyone made this shit working please ? ![]()
Thank a lot
last version:
esphome:
friendly_name: Clim Control1
on_boot:
priority: 1000.0
then:
- switch.turn_on: lcd_power
- delay: 500ms
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
wifi:
ssid: "Livebox-1F30"
password: "xxxxxxxxxxx"
power_save_mode: none
reboot_timeout: 15min
logger:
hardware_uart: USB_SERIAL_JTAG
api:
encryption:
key: "C/psM/***************="
ota:
- platform: esphome
password: ***************
i2c:
sda: GPIO38
scl: GPIO39
pcf8574:
- id: pcf_ext
address: 0x21
spi:
clk_pin: GPIO2
mosi_pin: GPIO1
output:
- platform: ledc
pin: GPIO6
frequency: 19531Hz
switch:
- platform: gpio
pin:
pcf8574: pcf_ext
number: 3
mode: OUTPUT
restore_mode: ALWAYS_ON
- platform: output
output: backlight
psram:
mode: octal
display:
- platform: st7701s
dimensions:
width: 480
height: 480
cs_pin: GPIO16
de_pin: GPIO40
hsync_pin: GPIO15
vsync_pin: GPIO7
pclk_pin: GPIO41
spi_mode: MODE3
color_order: RGB
invert_colors: true # Remis à false (zéro inversion parasite)
pclk_frequency: 16MHz
pclk_inverted: true # NOTRE SÉCURITÉ : Repassé à false
hsync_pulse_width: 10
hsync_back_porch: 50
hsync_front_porch: 10
vsync_pulse_width: 8
vsync_back_porch: 20
vsync_front_porch: 10
reset_pin:
pcf8574: pcf_ext
number: 4
mode: OUTPUT
data_pins:
red: [GPIO11, GPIO10, GPIO9, GPIO46, GPIO3]
green: [GPIO8, GPIO18, GPIO17, GPIO5, GPIO45, GPIO4]
blue: [GPIO47, GPIO21, GPIO14, GPIO13, GPIO12]
# FORCE LE REMPLISSAGE BLANC DIRECT POUR SQUELETTER LE SIGNAL
#lambda: |-
# it.fill(Color(255, 255, 255));
lvgl:
displays:
- my_display
widgets:
- label:
text: "BOOT OK"
align: CENTER
Thank for any working code or clues ![]()
