Lovelace 0.84.1 map card is not displayed
I have the map card on my lovelace Overview.
But since the 0.84.1 update it is displayed like an empty card.
Here is a screenshot:
grafik
I also use the .yaml configuration and it looks like this
  - type: map
    aspect_ratio: 100%
    entities:
      - device_tracker.wife
      - device_tracker.myphone
      - zone.home
      - zone.work
I am experiencing the same problem… any suggestions as to what could be the reason behind it?
I am having the same issue…I noticed if I remove the aspect ratio line the map appears.
I found the issue. The aspect ration is Not working with 100% anymore. I changed it to 16x9 and it works again
