Lovelace 404 error
Hi, I’m trying to run lovelace in yaml mode but when I reboot I’m getting a 404 error, I’ve created the ui-lovelace.yaml file . I’d appreciate your help
what does the homeassistant.log say?
Sounds like it’s not seeing it… where did you put the ui-lovelace.yaml? It doesn’t go in .storage, it’s in the same folder/directory as configuration.yaml
It says nothing, just logs regarding insteon and other components
Hi David, I’ve created it in the same subdir as configuration.yaml
I had a 404 error recently … clearing the browser’s cache and restarting my browser took care of the problem for me.
Thanks, I was really frustrated so I backed up my config and started with fresh install now it works.
