Lovelace Alarm Panel with hass.io: "Entity not available"
I’m trying to set up my HA as a home alarm system.
My hardware and software is: hass.io 0.106.2 (RPi 4)
I have read alot of guides but it’s hard to keep track of all the different integrations since it seems several has almost the same name? (alarm_panel_control ish…)
Now I’ve done a couple of tries but the lovelace card displayed is this:
alarm_control_panel_test
does anyone have any idea what i’m missing?
If it’s not obvious i’m a newbie on Home Assistant… :upside_down_face:
Below you can see my configuration…
configuration.yaml:
default_config:
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
discovery:
lovelace:
  mode: yaml
alarm_control_panel:
  - platform: manual
    entity: 'alarm_control_panel.alarm'
    code: 0000
    pending_time: 30
    delay_time: 20
    trigger_time: 4
    disarmed:
      trigger_time: 0
    armed_home:
      pending_time: 0
      delay_time: 0
automations.yaml:
- alias: 'Trigger alarm while armed away'
    - platform: state
      entity_id:
        - binary_sensor.openclose_6
        - binary_sensor.openclose_3
        - binary_sensor.openclose_2
      to: 'open'
  condition:
    - condition: state
      entity_id: alarm_control_panel.ha_alarm
      state: armed_away
    - service: alarm_control_panel.alarm_trigger
- alias: 'Send notification when alarm triggered'
    - platform: state
      to: 'triggered'
    - service: notify.notify
        message: "ALARM! The alarm has been triggered"
ui-lovelace.yaml:
title: Home
  - badges:
      - entity: person.peter
      - entity: sun.sun
    cards:
      - type: alarm-panel
        entity: alarm_control_panel.alarm
        states:
          - arm_home
          - arm_away
          - arm_night
      - entity: weather.home
        type: weather-forecast
      - entities:
          - binary_sensor.vibration_8
          - sensor.bedroom_multipurpose_sensor_battery_level
        type: entities
      - entities:
          - binary_sensor.vibration_5
          - sensor.kitchen_door_multipurpose_sensor_battery_level
        type: entities
      - entities:
          - sensor.openclose_2_battery_level
        type: entities
      - entities:
          - zwave.fibaro_system_fgsd002_smoke_sensor
          - sensor.fibaro_system_fgsd002_smoke_sensor_battery_level
          - sensor.fibaro_system_fgsd002_smoke_sensor_burglar
          - sensor.fibaro_system_fgsd002_smoke_sensor_general
          - sensor.fibaro_system_fgsd002_smoke_sensor_heat
          - sensor.fibaro_system_fgsd002_smoke_sensor_heat_2
          - sensor.fibaro_system_fgsd002_smoke_sensor_power_management
          - binary_sensor.fibaro_system_fgsd002_smoke_sensor_sensor
          - sensor.fibaro_system_fgsd002_smoke_sensor_smoke
          - sensor.fibaro_system_fgsd002_smoke_sensor_smoke_2
          - sensor.fibaro_system_fgsd002_smoke_sensor_sourcenodeid
          - sensor.fibaro_system_fgsd002_smoke_sensor_system
          - sensor.fibaro_system_fgsd002_smoke_sensor_temperature
        type: entities
    path: default_view
    title: Home
Go to Developer Tools ==> States and try to find “alarm_control_panel.alarm”.
Is there no error in the log? The alarm_contro_panel integration has no parameter entity, see the docs here. The entity_id of your alarm control panel should be alarm_control_panel.home_alarm because you defined Home Alarm as the name for the alarm control panel.
Thanks! I hadn’t understood the connection between a devices entity_id and it’s name attribute!
So if a name is defined then it will always be a part of the entity_id?
Depends on the integration, but a lot of integrations use name as the second part of the entity_id. The first part is always the domain.
