Lovelace: Button card
@elRadix, this is not @thomaslovenā€™s card.
Have you tried to increment the version number in the resources section of ui-lovelace.yaml?
Also i had to hammer CTRL-F5 multiple times.
Not having gone into the depths of the HA code yet is there a better example that could be used to that doesnā€™t make the cards rely on external sources?
Hopefully, we will see most of these features become part of the official entity-button card and then we donā€™t have to rely on external resources for these basic features.
For the ones that get errors since yesterday (custom:card not found) I just did this and it fixed the problem for me, go to your button-card.js file (default location /local/button-card.js, local is the www folder in your homeassistant installation) and edit the file with any text editor. Then replace line 3 with this address:
https://unpkg-gcp.firebaseapp.com/@polymer/[email protected]/lit-element.js?module
Then save and restart Home Assistant (donā€™t know if you have to restart it but I did it anyways :stuck_out_tongue:). When everything is back online refresh the page a few times as it will take a few tries. If it doesnā€™t clear out your browser cache and try again. They work fine for me now. Hope this helps.
Looks like someone have replaced the urls with localhost:5000? :rofl:
example for button card, weather card etc
https://unpkg.com/@polymer/[email protected]/lit-element.js?module=
its now:
import { PropertiesMixin } from "http://localhost:5000/@polymer/polymer@^3.0.2/lib/mixins/properties-mixin.js?module"; import { camelToDashCase } from "http://localhost:5000/@polymer/polymer@^3.0.2/lib/utils/case-map.js?module"; import { render } from "http://localhost:5000/lit-html@^0.10.0/lib/shady-render.js?module"; export { html, svg } from "http://localhost:5000/lit-html@^0.10.0/lib/lit-extended.js?module";
Its should be like previous version:
I see many custom cards tries to use the broken one at
Also same error for
https://unpkg.com/@polymer/lit-element@^0.6.4/lit-element.js?module
I dropped a new release folks. It includes a fix to the cdn url and custom icon for states.
I have just configured this card to use it as I could not change the colour of an input_boolean (using the core-card) when I switch on/off but this works GREAT!!
The only ā€˜issueā€™ is that I canā€™t edit this card when I use the new lovelace .storage mode.
I agree but as per discussion earlier here Iā€™m not going to hold my breath.
Thank you!
Thanks ! What do you think about storing local all the js files ?
Reply, I just updated the card as it was broken. Now itā€™s fixed again tnx for that! But I have an input_boolean configured, now when I press the button this show up:
It didnā€™t beforeā€¦how can I disable this popup?
Config:
    - type: "custom:button-card"
      icon: mdi:account-arrow-right
      color: rgb(28, 128, 199)
      #color_off: rgb(28, 128, 199)
      entity: input_boolean.scene_afwezig
Thaaanks :slight_smile:
hi guys,
for some reason my custom buttons have started failing
iā€™m on 0.85 which i updated to on release, yet these buttons on stopped loading today
Capture
cards:
  - card_style: ''
color: var(--primary-text-color)
color_off: var(--disabled-text-color)
color_type: icon
default_color: var(--primary-text-color)
entity: script.tvvolumeup
icon: 'mdi:volume-plus'
name: TV Volume Up
type: 'custom:button-card'
  - card_style: ''
color_type: icon
entity: script.tvvolumedown
icon: 'mdi:volume-minus'
name: TV VOLUME DOWN
type: horizontal-stack
Could someone please help me
fixed version now available (see a few posts further up)
Iā€™ve replaced the .js card with your updated version and restarted yet itā€™s still the same
What am I doing wrong?
did you delete cookies and all site data, cache?
I have now :slight_smile:
Thank you
YAY Updates!!! Thank you!
try with :
action: toggle
If I use hass.OSā€™s configure UI feature and hit edit on any of this cards they all get stuck loading. They work properly, just canā€™t edit them. Is there a fix for this?
How do you know the cards work if you cannot edit the cardā€™s settings? Which lovelace mode are you using?
