@RomRider immediately related to the post above, how can I use a top level variables:
variables:
speed_color: >
[[[ var speed = states['sensor.argon_one_addon_fan_speed'].state;
var mapper = {0:'green',
1:'darkgreen',
3:'orange',
33:'orangered'
66:'maroon'}
return mapper[speed] ? mapper[speed] : 'red' ; ]]]
in a custom fields style:
custom_fields:
fan:
[[[ return `<ha-icon icon=mdi:fan style='width:15px;color: var(--speed-color);'> </ha-icon>
<span style='color: var(--primary-color);'>
${states['sensor.argon_one_addon_fan_speed'].state} % </span>`; ]]]
replacing the color: var(--speed-color)
which I use up to now, with color: variables.speed_color
or even color: ${variables.speed_color}
is unsuccessful unfortunately. Canāt this be done?
It would be very cool, because I would only need the 1 top variable, and use it in more places of course
UPDATE:
yes we can:
custom_fields:
fan:
[[[ return `<ha-icon icon=mdi:fan style='width:15px;color: ` + variables.speed_color + `;'> </ha-icon>
thanks to Ildar.
Mariusthvdb:
33:'orangered'
again typo - missing comma
I am still trying, wait a littleā¦
no typo thereā¦Color Theory
oopsā¦ sorryā¦ also the closing third ]
was missingā¦
First, regarding color of fanās icon:
variables:
speed_color: |
[[[ var speed = states['sensor.iiyama_ohm_fans_fan_1'].state;
var mapper = {500:'green',
600:'darkgreen',
700:'orange',
800:'orangered',
900:'maroon'}
return mapper[speed] ? mapper[speed] : 'yellow'; ]]]
custom_fields:
fan: >
[[[ return `<ha-icon icon=mdi:fan style='width:32px;color: ` + variables.speed_color + `;'> </ha-icon>
${states['sensor.iiyama_ohm_fans_fan_1'].state} rpm </span>`; ]]]
Note this:
Do not bother about ā500,600,700ā, ārpmā, that was for my testing case.
Also, note that your construction "mapper"
works only for THESE values, i.e. for 500,600,700 - for 550, 650 it will return default value (this is not good)
A yes, that should work.
Thanks.
About the speeds: they are fixed in my fan add-on. So no worries about other speeds
Thatās why I didnāt make a Template with <
As for conditional rotation - add this style with card-mod, and define conditions for speeds:
type: custom:button-card
card_mod:
style: |
div#container > div#fan > ha-icon {
animation: rotation 1s linear infinite;
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(360deg);
Do not bother about colors & font-sizes - that was changed while reverse-engineering your code))
can we replace the ā1sā with a variables.speed_rotation ?
and encapsulate it in a template:
if (states['sensor.argon_one_addon_fan_speed'].state != 0) return
You can define "1s"
by using usual ways like:
animation:
{% if states('input_number.servicewithhistory_value')|int <= 250|int -%}
rotation 4s
{%- elif states('input_number.servicewithhistory_value')|int > 250|int and states('input_number.servicewithhistory_value')|int <= 500|int -%}
rotation 2s
{%- elif states('input_number.servicewithhistory_value')|int > 500|int and states('input_number.servicewithhistory_value')|int <= 750|int -%}
rotation 1s
{%- else -%}
rotation 0.3s
{%- endif %}
linear infinite;
of course, thats the jinja we needā¦
I was still trying to do this:
card_mod:
style: |
animation: rotation **variables.speed-rotation** linear infinite;
0% {
100% {
variables:
speed-rotation: >
var mapper = {0:'100s',
1:'4s',
3:'3s',
33:'2s',
66:'1s'}
return mapper[speed] ? mapper[speed] : '0.3s' ; ]]]
are you sure we can not load a variable there? not even a jinja version like
animation:
{% set speed = states('sensor.argon_one_addon_fan_speed')|int %}
{% if speed != 0 -%}
{% if speed == 1 %} rotation 4s
{% elif speed == 3 %} rotation 3s
{% elif speed == 33 %} rotation 2s
{% elif speed == 66 %} rotation 1s
{% else %} rotation 0.3s
{% endif %} linear infinite;
{% else %} null
{% endif %}
or
{% set mapper = {1:'4',3:'3',33:'2',66:'1'} %}
{% set rotation = mapper[speed] if speed in mapper else '0.3' %}
{{'rotation ' + rotation + 's ' + 'linear infinite'}}
{% else %} null
{% endif %}
edit:
YES! this works fine:
card_mod:
style: |
animation:
{% if speed != 0 %}
{% else %} null
{% endif %}
so cool ! thanks you once again @Ildar_Gabdullin
Great, I gonna save this info for future))
yes, I was hoping so.
main reason for not using card-mod, would be using templates in button-card is done in the browser, opposed to the card-mod jinja template in the backend server.
So if you still have a suggestion, I would certainly appreciate thatā¦
btw, I found another way to prevent using these messy html ticks:
toplevel
variables:
state_color: >
[[[ var state = entity.state;
if (state < 50) return 'green';
if (state < 60) return 'darkgreen';
if (state < 70) return 'orange';
if (state < 80) return 'maroon';
return 'red'; ]]]
and then use an intermediary --state-color:
styles:
custom_fields:
temp:
- --state-color: >
[[[ return variables.state_color ]]]
icon:
- color: >
as you can see you can reuse the same top level variable elsewhere
and finally the field itself:
custom_fields:
temp: >
[[[ return `<ha-icon icon=mdi:thermometer
style='width:15px; color: var(--state-color);'> </ha-icon>
${entity.state}Ā°C</span>`; ]]]
nice.
BTW, for animations you may use extra_styles
instead of "card_mod"
Something like this:
extra_styles: |
0% {
100% {
custom_fields:
fan: |
icon=mdi:fan
style='width: 32px;
color: red;
animation: rotation 4s linear infinite;'
</ha-icon>
<span
</span>
But for "extra_styles"
there is an issue in the docs:
Note: extra_styles MUST NOT be used on the first button-card of the current view, else it will be applied to all the cards in all Lovelace. It is not possible to fix this behaviour.
of course! I keep forgetting the extra_styles!
great, now we can use it all in the frontend browser. only thing left to find is the correct syntax to include my top level variables.speed_rotationā¦ will requires some extra tweaking, always a challenge
found it:
extra_styles: |
0% {
100% {
variables:
speed_rotation: >
var mapper = {1:'4s',3:'3s',33:'2s',66:'1s'}
if (speed != 0)
return mapper[speed] ? mapper[speed] : '0.3s';
return null; ]]]
and
custom_fields:
fan:
icon=mdi:fan
style='width:15px;
animation: rotation ` + variables.speed_rotation + ` linear infinite;'
> </ha-icon>
although technically it now does
animation: rotation null linear infinite;
on speed 0. so I need to improve the template on that. Does work though
EDIT:
this is better
variables:
speed_rotation: >
var mapper = {1:'4s',3:'3s',33:'2s',66:'1s'};
var motion = mapper[speed] ? mapper[speed] : '0.3s';
if (speed != 0) return 'rotation ' + motion + ' linear infinite';
return null; ]]]
custom_fields:
fan:
icon=mdi:fan
style='width:15px;
color: `+ variables.speed_color +`;
animation: `+ variables.speed_rotation +`;'
> </ha-icon>
seems the frame rate isnt high enough for the 100% speedā¦
so hereās a small gif in HD
btw, and believe it or not, but this is the first card-mod on a regular entity I (have to) use, (because the entity is made by an add-on, and custom-ui cant customize theseā¦)
so please let me ask, if this is the correct way I can do that (it is working as expected):
- entity: sensor.argon_one_addon_fan_speed
secondary_info: last-changed
card_mod:
style:
hui-generic-entity-row:
state-badge:
ha-icon:
ha-svg-icon {
color:
{% set mapper = {0:'green',1:'darkgreen',3:'orange',
33:'orangered',66:'maroon'} %}
{{ mapper[speed] if speed in mapper else 'red'}}
in the set speed
I need to call the entity completely dont I? I cant use something like entity.state
or states(config.entity)
ā¦
Yep, confirmed, states(config.entity)
does the trick. Nice, great for yaml anchors
o heck, this is not a button-card, sorry for the wrong thread, continuing from above thoughā¦
Hello, Iām breaking my head here.
Iām trying to build a card similar to grid example listed in the documentation. So bring together multiple data parts into one small card.
The problem Iām facing I want to change icons if I detect motion (different state) use mdi:motion-sensor and if not mdi:motion-sensor-off.
My code looks like
title: Master Test
path: master_test
icon: "mdi:account-supervisor-circle"
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: "custom:button-card"
triggers_update:
- sun.sun
icon: "zeus:shower"
styles:
card:
# - aspect_ratio: 1/1
- width: 120px
- height: 100px
- margin: 3px
- padding: 5px
- border-radius: 15px
- background-color: var(--primary-background-color)
- box-shadow: >
if (states['sun.sun'].state == "below_horizon")
return '-5px -5px 15px #2c2c2c, 5px 5px 15px #191919';
else if (states['sun.sun'].state == "above_horizon")
return '-5px -5px 15px #ffffff, 5px 5px 15px #ebebeb';
grid:
- grid-template-areas: '"i Motion" "i Window" "i Water"'
- grid-template-columns: 4fr 1fr
- grid-template-rows: 1fr 1fr 1fr
img_cell:
- justify-content: start
- align-items: start
icon:
- width: 50%
- color: deepskyblue
custom_fields:
Motion:
- align-self: middle
- justify-self: end
- font-size: 10px
- --text-color-sensor: '[[[ if (states["binary_sensor.motion_sensor_master_bathroom_occupancy"].state == "on") return "red"; ]]]'
- --icon-type: >
if (states["binary_sensor.motion_sensor_master_bathroom_occupancy"].state == "on") return "mdi:motion-sensor";
else return "mdi:motion-sensor-off";
Window:
- justify-self: end
- font-size: 10px
- --text-color-sensor: '[[[ if (states["binary_sensor.motion_sensor_master_bathroom_occupancy"].state == "off") return "red"; ]]]'
Water:
- justify-self: end
- font-size: 10px
- --text-color-sensor: '[[[ if (states["sensor.processor_use_percent"].state > 60) return "red"; ]]]'
custom_fields:
Motion: >
return `<ha-icon
icon= var(--icon-type)
style="width: 20px; height: 20px;">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states["sensor.disk_use_percent_home"].state}%</span></span>`
Window: >
return `<ha-icon
icon= "mdi:memory"
style="width: 25px; height: 25px;">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${Math.round(states["sensor.memory_free"].state /1000)}GB</span></span>`
Water: >
return `<ha-icon
icon= "mdi:cpu-64-bit"
</ha-icon><span> <spanstyle="color: var(--text-color-sensor);">${states["sensor.processor_use_percent"].state}%</span></span>`
Can someone help me figure out what Iām missing? Currently I have this template for confirmation on tap_action, which works (copied from the docs).
confirmation:
text: '[[[ return `Hiermee wordt ${entity.attributes.friendly_name} aan/uitgezet, doorgaan?` ]]]'
Now I want the text to say either A or B depending on the state of the entity. So I have this, but it doesnāt work:
confirmation:
text: '[[[ if (entity.state === on) return "Hiermee wordt ${entity.attributes.friendly_name} uitgezet, doorgaan?"; else return "Hiermee wordt ${entity.attributes.friendly_name} aangezet, doorgaan?" ]]]'
I think Iām missing something obvious or am combing templates the wrong way.
try for starters:
[[[ if (entity.state == 'on')
return `Hiermee wordt ${entity.attributes.friendly_name} uitgezet, doorgaan?`;
return `Hiermee wordt ${entity.attributes.friendly_name} aangezet, doorgaan?` ]]]
