[Lovelace Card] Pool Monitoring Card - Pool temperature, pH, ORP and TDS
Hi @bcre3306 @K4BlOs, it’s now possible in version 2.0 just relased
Hi @sigalou , this card is preconfigurated for pool sensors, what are the sensor type for air quality ?
:zap: Release Notes: Version 2.0 :zap:
:rocket: Version 2.0 is here! This release is a complete overhaul, bringing exciting new features, a more intuitive user experience, and a more maintainable structure.
:star2: What’s New?
:wrench: Improved User Experience
  • Support for multiple entities per sensor type
    Easily configure and monitor multiple sensors, all in one place.
    (#25, #43)
  • Organized sensor display for better clarity
    Enjoy a cleaner, more intuitive layout for all your sensors.
    (#11)
  • Gradient bar and flexible layout options
    Customize your display with a stunning gradient bar and layout flexibility.
    (#48)
  • :warning: Configuration Update Required
    The configuration structure has been revamped to use sensors and display objects.
    :red_circle: Action Needed: Migrate your YAML configuration from v1 to v2. Learn more.
:hammer_and_wrench: Enhanced Maintainability
  • Modular architecture
    Simplifies updates and makes the project more scalable.
    (#12)
  • Advanced translation support
    Multi-language support to cater to a global audience.
  • Improved error handling
    Get clear and actionable error messages for easier debugging.
:link: Related Issues
  • #25 - YAML configuration arrays vs. single configurables
  • #43 - Support for multiple pH sensors
  • #11 - Reorder sensor displays
  • #48 - Gradient bar and layout options
  • #12 - Set minimum limit values
:open_book: Migration Guide
To help you transition your configuration from v1 to v2, follow these steps:
  1. Replace old sensor definitions with the new sensors object.
  2. Update display settings using the new display object.
  3. Refer to the updated documentation for detailed YAML examples.
:point_right: View the Full Migration Guide
Thank you for your continued support! :blue_heart:
This is great! :pray::raised_hands::heart:
I have Jandy iAquaLink without water chemical /pH , treatment, balance, or maintenance capabilities. Currently I can monitor water / air temp, pump status, freeze protection, water features, and lights.
Definitely interest in expanding my Jandy system.
The sensor icons are awesome!
Those of you using this card, can you share your card configs?
Same! I’d love to add my iAquaLink air temp sensor
How to change temp to Fahrenheit from celsius?
Hello, you have a property unit in all sensors. Example
temperature:
- entity: sensor.pool_water_temp
name: ‘Water Temperature’
unit: ‘°F’
Sweet! That did the trick. Not sure how I overlooked that unit property. Thank you so much!
UPDATE:
Here’s my manual card config:
type: custom:pool-monitor-card
sensors:
  temperature:
    - entity: sensor.pool_temp
      name: Water Temperature
      setpoint: 85
      unit: ‘°F’
    - entity: sensor.air_temp
      name: Air Temperature
      setpoint: 36
      unit: ‘°F’
  orp:
    - entity: sensor.orp
      name: Oxidation Reduction
  salinity:
    - entity: sensor.spa_salinity
For the associated top card in this dashboard view:
I now want to invest in chemical and water level smart capabilities :money_mouth_face:
What’s everyone using for pool or hottub chemical balance and water levels that’s support by this?
I’m not looking to break the bank, because you can easily do that with this type of stuff.
Hopefully there’s some reliable highly rated add-on Solutions that I can use with my Jandy iAquaLink and Master Spas hot tub
Hi!
Do you think it can be used for other purposes?
The graphics are cute and I cannot find anything that can replicate it!!!
For example, I would like to visualise some data from the photovoltaic system:
Current production: Range 0 to 6000 kWh
Overproduction: Range 0 to 6000 kWh
Battery capacity: 0 to 100%
House current consumption: 0 to 6000 kWh
As it is, I can’t see the value from 0 to the upper limit.
Must be integrated or am I wrong somewhere?!
Thanks in advance!
Hi @ennebie , I’m working on a spin-off that will enable this functionality, and it should be out soon, so I’ll keep you posted.
Wow! good to know!
Can’t wait for it! Hope to see it soon!
I warn you, I’m buying you a coffee :smiley:
This : Amazon.fr
This would be pretty amazing also as just a heat and humidity card for a room.
Fantastic card. A few suggestions or requests:
Ability to adjust size of elements, font etc, the card doesn’t seem to work with card mod.
Ability to customize sensors/types so it can be used beyond just pool items, for example pollen or UV.
Thank you so much, this card is extremely useful!
I do have one problem that I cannot seem to figure out - the colors option does not seem to work … I might be missing something?
Just for kicks I changed all the colors to the same one so I can make sure it is obvious if it works - and it does not :frowning: Any pointers?
My card:
The YAML:
colors:
  normal_color: "#881531"
  low_color: "#881531"
  warn_color: "#881531"
  cool_color: "#881531"
  marker_color: "#881531"
  hi_low_color: "#881531"
sensors:
  temperature:
    - entity: sensor.waterguru_theoasis_water_temperature
  ph:
    - entity: sensor.waterguru_theoasis_ph
Wow a really great card, thank you!
How do yo measure your values for ph, orp, etc?
Anyone using a non china metering solution like an esp32 or something else?
my Ospa Pool central delivers Chlor mg/l
What is the right sensor vor a value like 0.5mg/l ? Because if I use free_chlorine I get a Scala with the wrong thresholds… 3.0mg/l seems to bee too high if I ask the internet…
sensors:
  free_chlorine:
    - entity: sensor.chlor
      min: 0.3
      max: 0.6
  ph:
    - entity: sensor.ph_wert
  orp:
    - entity: sensor.redox_wert
  temperature:
    - entity: sensor.wassertemperatur
fixed it with these settings:
title: Poolüberwachung
sensors:
temperature:
ph:
free_chlorine:
setpoint: 0.5
step: 0.15
orp:
Hi
Thanks for sharing. Works fine with my Bayrol.
BUT I have a question. How can I change the background Transparenz.
I can change it in all my cards with card-mod, but it dosn’t work with Pool Monitor cards.
Does anyone have any idea how I can make the background transparent and the map borderless?
Thank you
display:
  compact: true
  show_names: false
  show_labels: true
  show_last_updated: true
  show_icons: true
  show_units: true
  language: de
colors:
  normal: "#00BFff"
  low: "#90EE90"
  warn: "#FFD700"
  marker: "#FF4500"
  hi_low: "#8A2BE2"
sensors:
  ph:
    - entity: sensor.bayrol_22acl2_00744_ph
  orp:
    - entity: sensor.bayrol_22acl2_00744_redox
card_mod:
  style: |
    ha-card {
      background: rgba(50, 50, 50, 0.0);
