Lovelace config overwritten
I finally got around to configuring the Lovelace UI, and was in the process of adding a floorplan panel. I saved the initial floorplan with just a couple of things…a template, sort of…using the UI. Then a few days later I spent a few hours getting all items in and aligned. It was a good start.
This weekend, I added a new switch. I edited the default Lovelace (now not system controlled) page to add the switch. And I just noticed that saving that overwrote the hours of floorplan work back to just the initial template!
Luckily I have good backups and can get the config back, but this seems like a bug. What I think happened was I used one device to do the initial setup and switch, but a different one to do the bulk of the work. I think the first device had the old setup cached and overwrote it.
Is there a better place to log bug reports?
Actual bug reports go on Github
Done. https://github.com/home-assistant/home-assistant-polymer/issues/2980
I’m still a newb. :slight_smile:
Thanks.
