Lovelace: Decluttering Card
Read in card-mod docs about mod-card.
You need to place your card inside mod-card and style it.
Thanks for the quick reply Ildar.
I’ve tried with the mod-card following your suggestion, but still no luck. Not sure what I’m doing wrong. This is the current code:
  template_device_colored_icon:
    card:
      type: custom:mod-card
      card_mod:
        style: |
          :host {
            --card-mod-icon-color: 'green'
      card:
        type: custom:template-entity-row
        entity: '[[entity]]'
        icon: '[[icon]]'
I do not think you can use this css variable here. But try removing quotes around a value.
Also, the template-entity+row has its own “color” option.
Yay! Thank you! Removing the quotes did the trick.
However I don’t understand why for non-decluttering card it works with quotes. I mean, the code is copied from the working version without decluttering.
Cannot tell. In my observations, quotes may be converted in a browser/companion app in to some “other quotes” that are wrongly processed.
have 2 xbox remote cards which I want to put in a decluttering. All is well. except for card_modding the header
I can do this
type: picture-elements
title: Xbox Library
card_mod: !include /config/dashboard/card_mods/card-header-glance.yaml
visibility:
  - condition: state
    entity: device_tracker.xbox_library
    state: home
image: >-
  data:image/svg+xml;base64,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
elements:
which makes the header in style in my setup
moving that complete card to the decluttering works perfectly, except for the styling…
card:
#   card_mod: #!include /config/dashboard/card_mods/card-header-glance.yaml
#     style: '[[style]]'
  title: Xbox [[name]]
  visibility:
    - condition: state
      entity: device_tracker.xbox_[[id]]
      state: home
  image: >-
  elements:
Ive tried:
use regular include (I have many !includes in my decluttering templates working as is)
use verbose card_mod in the config section of the template
even tried to pass the style as a variable…
type: custom:decluttering-card
template: xbox_remote
variables:
  - name: Auditorium
  - id: id
  - style:
        ha-card {
          box-shadow: var(--box-shadow);
      ha-card:
          .card-header {
             background: var(--background-color-off);
             font-weight: 400 !important;
             font-size: 20px !important;
             color: var(--text-color-off) !important;
             padding:4px 12px !important;
anyone here that has made it happen yet?
please let me know
Picture elements has own ha-card , so there should be no need to to pass a cardmod code as a variable. In general, when passing a complex structure like a list or a dictionary - do not place “[[…]]” in quotes.
exactly what I thought, thats why I first tried:
card:
  visibility:
    - condition: state
      state: home
  image: >-
    data:image/svg+xml;base64,PD94bWwgdmVyc2lvbj0iMS4wetcetcetce
  elements:
the same !include that works in the full picture-elements, but using that in the decluttering template makes it do exactly nothing
You are trying to use a dictionary-like card-mod code for the card. Suggest to test with the SIMPLEST similar example. Perhaps there is smth wrong with the card mod code… Cannot help more, away from pc.
cards:
  - type: custom:decluttering-card
    template: xbox_template
    variables:
      - name: Auditorium
dectluttering template
xbox_template:
  card:
    card_mod: !include /config/dashboards/card-header-style.yaml
    elements:
      - type: state-icon
        style:
          left: 50%
          top: 50%
        entity: sensor.sun_next_dawn
    image:
header-style
style:
    .card-header {
      background: red !important;
      color: white !important;
weird… but good to see.
let me try that shorter dom path.
nope doesnt do anything…
but wait let me try another peculiarity…in my personal setup with card-mod versions…
right…
using card-mod version 3.4.5 and
    style:
        .card-header {
works as hoped for. Can also drop that in an include and do:
card:
  card_mod: !include /config/dashboard/card_mods/card-header-picture-elements.yaml
#     style:
#         .card-header {
#           background: red !important;
#           font-weight: 400 !important;
#           font-size: 20px !important;
#           color: white !important;
#           padding:4px 12px !important;
#   visibility:
#     - condition: state
#       entity: device_tracker.xbox_[[id]]
#       state: home
  image: >-
and now the exception.
since card-mod 3.5.0 which I am using requires the extra `ha-card’
style:
    ha-card {
  ha-card:
      .card-header {
         padding: 4px 12px !important;
         margin: 0px 0px 16px 0px !important;
and that works perfectly with a verbose picture-elements, I also used that in the decluttering template. Because, why not, all other includes work, so this should not be an exception.
Except it is…
thanks for testing, and sorry for bothering with my card-mod 3.5.0 troubles.
Ive been able to mitigate most all of the ‘incompatibilities’ so far, this is an extra challenge, maybe I need yet another step in the dom…
Been trying to get this to work for hours. What am I missing for these plex cards? I’m trying to get the players to show up whenever someone is watching.
decluttering_templates:
  plex_media_card:
    default:
      - ENTITY: media_player.none
    card:
      type: custom:mushroom-media-player-card
      entity: '[[ENTITY]]'
      icon: mdi:plex
      icon_color: purple
      media_info: current
      show_volume_level: false
      tap_action:
        action: more-info
      hold_action:
        action: toggle
  debug_plex_entity:
    default:
      - ENTITY: unknown
    card:
      type: markdown
      content: |
          const e = states[variables[0]];
          if (!e) return `## Debug Output\n**Passed Entity:** ${variables[0]}\n\nEntity not found.`;
          const a = e.attributes;
          return `## Debug Output\n` +
                 `**Entity ID:** ${e.entity_id}\n` +
                 `**State:** ${e.state}\n` +
                 `**Title:** ${a.media_title || 'n/a'}\n` +
                 `**Series:** ${a.media_series_title || 'n/a'}\n` +
                 `**Season:** ${a.media_season || 'n/a'}\n` +
                 `**Episode:** ${a.media_episode || 'n/a'}\n` +
                 `**Summary:** ${a.media_summary || 'n/a'}\n` +
                 `**Username:** ${a.username || 'n/a'}\n` +
                 `**Position:** ${a.media_position || 'n/a'} / ${a.media_duration || 'n/a'}\n` +
                 `**Muted:** ${a.is_volume_muted}`;
  - title: Home
    path: home
    icon: mdi:home
    cards:
        template: plex_media_card
        variables:
          - ENTITY: media_player.plex_plex_web_chrome_windows
        template: debug_plex_entity
        variables:
          - media_player.plex_plex_web_chrome_windows
      - type: custom:auto-entities
        card:
          type: vertical-stack
        card_param: cards
        show_empty: true
        filter:
          include:
            - domain: media_player
              entity_id: media_player.plex_*
              state: /playing|paused|on/
              options:
                variables:
                  - ENTITY: '[[entity]]'
what is the actual issue? you didnt say what doesnt work, or where the problem lies.
You should quote the ‘on’ in that state filter btw.
interesting, looking for the same a long time ago didnt trigger me to use decluttering card, in stead I do this
        show_empty: false
        visibility:
          - condition: numeric_state
            entity: sensor.plex
            above: 0
        card:
          type: entities
        filter:
          include:
            - entity_id: media_player.plex_*
              state: /playing|paused|'on'/
              options:
                !include /config/dashboard/includes/include_plex_playing.yaml
and throw in my include:
#https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card/120744/2193?u=mariusthvdb
type: custom:hui-element
card_type: vertical-stack
card_mod: #!include /config/dashboard/card_mods/stack_card_gap_shadow.yaml
  style: |
    div#root {
      margin: -16px;
    :host {
      --stack-card-gap: 0;
cards:
  - type: custom:button-card
    template: button_default_title
      [[[ var caption = 'Plex playing:&nbsp';
          var title = states['this.entity_id'].attributes.media_title;
          var artist = states['this.entity_id'].attributes.media_artist;
          var album  = states['this.entity_id'].attributes.media_album_name;
          return `<div style='display: flex; padding: 0px 16px 0px 0px;'>
              <div>${caption}</div>
              <marquee>
              <span style='color:silver;align-items:center;'>${artist} - ${album} - ${title}</span>
              </marquee>`; ]]]
    show_icon: false
    styles:
      card:
        - color: orange
        - background: black
  - type: markdown
    card_mod:
      style: |
        ha-card {
          background-image: url('/local/various/plex.png');
          background-position: right top;
          background-size: 180px;
          background-repeat: no-repeat;
          color: silver;
          --card-background-color: black
    content: >
      {% set player = 'this.entity_id' %}
      {% if states(player) not in ['unknown','unavailable'] %}
      <font color='orange'>**User:**</font> {{state_attr(player,'username')}}
      {% for attr in states[player].attributes %}
        {%- if not attr in ['media_content_id','icon','entity_picture','hide_attributes',
                            'media_position_updated_at','media_duration','media_position',
                            'player_source','media_content_rating',
                            'is_volume_muted','username','friendly_name','volume_level',
                            'supported_features'] %}
       <font color=orange> **{{attr.split('media_')[1]|replace('_',' ')|title}}:**</font> {{states[player].attributes[attr]|title}} {% endif %}
      {%- endfor %}
      {% else %} Nothing playing
      {% endif %}
  - type: picture
    image: /local/images/transparent.png
    card_mod:
      style: |
        ha-card {
          padding: 8px;
          background: url({{state_attr('this.entity_id','entity_picture')}});
          background-size: cover;
maybe decluttering is just as nice, although it has its quirks, and one has to be very careful for not all modifications tend to get transposed as wished for.
Sorry, it seems like it can’t find the entity. Keep getting entity not found. The debug also seems like it’s not evaluating any results.
Also is there a better way to debug these type of issues?
This is what is showing up on my dashboard.
I love the card so far but ran into an issue that I just have not been able to fix. I can pass the icon color to use and that works without any issues but if I read a sensor that has a string color value and want to pass that value as the color it just doesn’t work. I have tried to send a calculated result like {{states(‘sensor.alarm_status_color’)}}. If I do the same in developer tools I get a proper return that is a string value. Has anyone else ever got it to work sending a calculated color value?
you can’t use jinja template in variables.
Not sure if I’m doing something wrong, or this only works with strings…
Here’s an example I was trying to do with the gauge card:
  fridge_gauge:
    default:
      min: 25
      max: 48
      needle: false
      seg0_from: -200
      seg1_from: 33
      seg2_from: 35
      seg3_from: 38
      seg4_from: 40
    card:
      type: gauge
      needle: '[[needle]]'
      min: '[[min]]'
      max: '[[max]]'
      segments:
          color: var(--error-color)
          color: var(--warning-color)
          color: var(--success-color)
Neither the boolean for the needle nor the numeric values seem to properly work.
Not enough info.
How are you calling it? What is working and what actually is not? Any errors? Log entries?
            template: fridge_gauge
            variables:
              - entity: sensor.gw1100b_temperature_2
If I replace the ‘[[max]]’ and other values with actual numbers, it works. If i go back to the variables, it fails to render the widget properly. As an example with the needle, it doesn’t actually set to false/the needle is vislble. You can see in my example the default value for it should be false…
Figured it out… The defaults are supposed to be an array, I didn’t have them as an array.
