Lovelace Icon Animation Help
Hello HA Community! Having an issue getting a custom SVG animation to run in HA, and need some assistance.
I created the following custom rain drop animation that I want to display when a script is running that controls my automatic watering system:
<svg xmlns="http://www.w3.org/2000/svg" width="100" height="100" viewBox="0 0 100 100">
  <defs>
    <radialGradient id="rg" r="1" fx="0.25" fy="0.5">
      <stop offset="0%" stop-color="white"></stop>
      <stop offset="75%" stop-color="#1B7FE4"></stop>
    </radialGradient>
  </defs>
  <!-- Group for droplet animation with transformation -->
  <g transform="translate(50, 0) rotate(90, 50, 50)">
    <!-- Teardrop shape -->
    <path fill="url(#rg)" d="M 50,10
             c -40,50 -20,50 0,80
             c 40,-40 20,-50 0,-80" />
    <!-- Falling drop animation -->
    <animateTransform attributeName="transform" type="translate" dur="2s" repeatCount="indefinite" values="0,0;0,60" keyTimes="0;1"/>
  </g>
</svg>
I have dropped this “droplet_animation.svg” into my homeassistant/www directory and then to test if it works, just referencing it in a picture elements card:
type: picture-elements
image: /config/www/droplet_animation.SVG
elements:
  - type: image
    style:
      left: 50%
      top: 50%
      width: 100px
      height: 100px
      transform: translate(-50%, -50%)
but I the card just shows up like this:
It looks like HA at least likes the syntax from looking at it in my Studio Code Server running in HA:
And my config.yaml lovelace resources:
lovelace:
  resources:
    - url: /hacsfiles/aarlo-glance/aarlo-glance.js
      type: module
    - url: /hacsfiles/lovelace-card-mod/card-mod.js
      type: module
    - url: /hacsfiles/button-card/button-card.js
      type: module
    - url: /local/droplet_animation.svg   # Custom raindrop animation made for sprinkler system
But for some reason it’s not working. I have also tried creating a resource in my lovelace config, referencing the local filepath as the directory as well with no luck. I have confirmed that the animation works when I just open the svg file on my Windows PC, but it doesn’t work in here. Any suggestions?
try
image: /local/droplet_animation.SVG
That was it! Omg I was so close haha. Weird thing though, as soon as I put the appropriate code in, it broke another card that was working (my ultimate goal on this card) which referenced the same element. Now I’m getting "custom element doesn’t exist: button-card.
type: custom:button-card
entity: script.1718301656716
name: Start Watering Sequence
show_state: true
tap_action:
  action: call-service
  service: script.turn_on
  service_data:
    entity_id: script.1718301656716
styles:
  card:
    - width: 200px
    - height: 100px
    - background: |
          return entity.state === 'on' ? 'lightgreen' : 'white';
  name:
    - font-size: 14px
  icon:
    - color: |
          return entity.state === 'on' ? 'cyan' : 'gray';
    - width: 40px
    - height: 40px
  state:
    - font-size: 12px
  grid:
    - position: relative
    - align-items: center
    - justify-items: center
    - template: |
          if (entity.state === 'on') {
            return `
              <img src="/local/droplet_animation.svg" style="width: 40px; height: 40px;">
          } else {
            return `
              <ha-icon icon="mdi:water"></ha-icon>
Any ideas on why that would happen, or what I need to do to fix it and correctly reference this animation? Trying to display this when watering, and just a plain old gray water icon when the script isn’t running. Thanks
Re-download or re-install Custom Button-Card via HACs if this is the message you are seeing.
It will not affect your Lovelace code.
Thanks, that worked too. I know in this code I already had an icon that changes color based on state, but I want the on state to change from the lightgreen background and cyan icon to the svg animation with the lightgreen background. Tried this but it only displays the color changes with no icon at all, and some text in the background that says [object Object][object Object]:
entity: script.test_script
show_state: true
tap_action:
  service_data:
    entity_id: script.test_script
styles:
  card:
    - width: 200px
    - height: 100px
    - background-color: |
  name:
    - font-size: 14px
  icon:
    - display: none
  state:
    - font-size: 12px
  grid:
custom_fields:
  svg_icon:
    - position: absolute
    - top: 50%
    - left: 50%
    - transform: translate(-50%, -50%)
    - width: 40px
    - height: 40px
    - content: |
            ? '<img src="/local/droplet_animation.svg" style="width: 40px; height: 40px;">'
            : '<ha-icon icon="mdi:water" style="width: 40px; height: 40px;"></ha-icon>';
Any ideas on what I’m missing?
  1. This line is removing the icon
  icon:
    - display: none
  1. You have switched from template: | - content: | from the original code?
The code has significant changes from 1 hour ago
You also have an indent issue with custom_fields
try this
show_state: true
tap_action:
  service_data:
styles:
  card:
    - width: 200px
    - height: 100px
  name:
    - font-size: 14px
  icon:
    - color: |
    - width: 40px
    - height: 40px
  state:
    - font-size: 12px
  grid:
  custom_fields:
   svg_icon:
    - top: 50%
    - left: 50%
    - width: 40px
    - height: 40px
    - content: |
Yea I tried my old code and it didn’t work, so I threw it into ChatGPT just to see if it could figure it out. It changed the code around like you saw, but it also didn’t work. I also didn’t want to trigger the original script because it’s actually doing things I don’t want to keep triggering. So I replaced it with the test_script. Below, I’ll paste the original code I was working on, but replacing it with the test script. It all works except when I turn it on, it won’t display the svg animation. It just displays the cyan icon. What should I do to replace the cyan icon with the svg animation when it runs?
show_state: true
tap_action:
  service_data:
styles:
  card:
    - width: 200px
    - height: 100px
    - background: |
  name:
    - font-size: 14px
  icon:
    - color: |
    - width: 40px
    - height: 40px
  state:
    - font-size: 12px
  grid:
    - template: |
            return `
          } else {
            return `
I have a button card that uses an SVG and my code is under entity_picture.
chrome-capture-2024-6-13
Here is a portion of the code
        entity: fan.bedroom_fan
        icon: mdi:fan
        show_state: false
        show_name: false
        show_entity_picture: true
        entity_picture: |
          if (states['sensor.fan_direction_speed'].state == 'forward16')
          return "/local/animated/forward16.svg";
          else return "/local/pics/tr2.png";
Tried your code from your edited post and it functions the same as the code I just posted.
        icon: mdi:fan
        show_state: false
        show_name: false
        entity_picture: |
I’ll try to adapt my code to work with this. I currently don’t have a still image for the off state like you do. Can I just use a mdi:icon return instead of your path in the “else return” part?
Test this first and we can tackle the the little things once we get your SVG working.
icon: mdi:fan
show_state: false
show_name: false
entity_picture: |
          if (states['script.test_script'].state == 'on')
          return "/local/droplet_animation.svg";
          else return "/local/droplet_animation.svg";
styles:
  card:
    - width: 200px
    - height: 100px
    - background: |
size: 100% controls the size of the SVG so if the SVG is too big adjust the percentage to a lower value.
Tested it at 50% size and it looks like this when I run the script:
Never shows the svg.
do you have the SVG inside the WWW folder?
/local/ = www
Yes, check the original post, I took a SS of my config folder through Studio Code Server.
This code works:
elements:
  - type: image
    style:
      left: 50%
      top: 50%
      width: 100px
      height: 100px
When you double click the animation in the file editor it should open up the file in your browser and the SVG should appear and move. Does that happen?
Nothing happens when I double click on it.
But it works on the custom picture elements card
I should have said one click
I tested both. Single or double click does nothing
rename it to all lowercase .SVG needs to be .svg
That worked! And it made your latest code work:
icon: mdi:fan
show_state: false
show_name: false
entity_picture: |
styles:
  card:
    - width: 200px
    - height: 100px
    - background: |
But this still doesn’t work:
show_state: true
tap_action:
  service_data:
styles:
  card:
    - width: 200px
    - height: 100px
  name:
    - font-size: 14px
  icon:
    - color: |
    - width: 40px
    - height: 40px
  state:
    - font-size: 12px
  grid:
  custom_fields:
    svg_icon:
      - top: 50%
      - left: 50%
      - width: 40px
      - height: 40px
      - content: |
Getting closer!!!
I haven’t added an svg in this manner so I’d have to do some testing.
So I understand, what are you trying to achieve with the 2nd code set? Is it only to show the icon when the state is OFF?
