My Worx S500 is up and running again - thanx a million for your work!
Hi there.
After updating to the new landroid cloud version (coming from 1.8.2) and to the new card
i see that all sensors are gone and now there are attributes only.
In addition to that it’s one attribute for several states.
I created this complete page for the old versions and I got no idea how to get this working again now:
At the moment I am trying to figure out how to get template sensors for these attributes running,
but i stumble upon this:
For example, when I enter the following into developer template
{{ states.vacuum.robby.attributes.firmware.version }}
i got the result: “3.27”
but if I enter it this way:
{{ state_attr(‘vacuum.robby’, ‘firmware.version’) }}
the result is: “none”
If I only enter firmware (without.version),
both results are “{‘auto_upgrade’: False, ‘version’: 3.27}”
Same problem if I use attribute on an entities-card:
- type: entities
- type: attribute
entity: vacuum.robby
attribute: firmware.version
- type: attribute
it doesn’t work.
Is there anybody who can help me with this issue?
Thank you.
Make template sensors like this:
- Version → value_template: “{{ state_attr(‘vacuum.robby’, ‘firmware’).version }}”
- Auto Upgrade → value_template: “{{ state_attr(‘vacuum.robby’, ‘firmware’).auto_upgrade }}”
- Bladetime → value_template: “{{ state_attr(‘vacuum.robby’, ‘blades’).current_on }}”
etc. etc.
And
{{ state_attr('vacuum.robby', 'schedule').primary.monday.start }}
{{ state_attr('vacuum.robby', 'capabilities')[0] }}
11:00
Edge Cut
Thanks a lot for your help.
I tried everything except the point after the closed bracket.
Any idea about the correct syntax for the attribute on the entities card?
I made use of it before the update and there was no need to add template sensors.
Here’s an example of the old config.
No idea how to deal with nested attributes in an Entity Card, but you could create sensors for all the items you are interested in (Batteriespannung, Batterietemperatur, Ladezyklen, etc.) and then put them as entities in an Elements Card,
Hi
Since some days I have a problem communication with my robot. In android app everything ok. I can see robot status and I can send any commands to it.
In Hassio something went wrong. Landroid Coluds connected to Worx server. Integration can read robot name. (if I change in the android app also change in Hassio to.). But thats all.
Status is : Initializing.
No information about moving, charging, blade time . etc. Also can’t send commands to the robots. I get MQTT connection issue…
I already deleted all parts, and reinstall again. Robot was repairing too. No solution.
Does anyone have similar problems?
I know this forum for Lovelace card, but I not found better forum.
(All parts are up to date)
Thanks.
Hi there,
I created a video for the worx landroid using the updated method with the landroid cloud and the landroid card. In case you need video guidance jut have a watch.
It is in german though, but you can use auto subtitle from youtube
Hope it helps
Any wishes for Landroid_Cloud v3?
I’m currently doing the finishing touches for making the pyWorxCloud module fully compliant with the API as documentented by Positec.
Shortly I’ll begin adapting this to the Landroid_Cloud integration, so if you have some wishes for the new major overhaul of the integration, speak up now
