Lovelace map card zoom level
Is it possible to set the zoom level of a map card?
Mine default to being zoomed in to maximum.
It is not. If you add zones to it, it will zoom to fit all the zones.
Ok thanks, but that is not terribly useful if I just want to show one device_tracker.
Or one device_tracker and one zone when the device_tracker is in the zone.
It’s no big deal, I know it is all experimental at the moment but it would be good if the map card could be a touch more configurable.
Whatever the case I am loving the speed with which you can experiment with Lovelace!
if you put your home zone in there and the device tracker, it should always show you a zoom level where you can see both. It just won’t be zoomed out when you are home, only when away.
There is a request in for that.
Hi, any news about this, it should be the option to just zoom one device_tracker
It is…
default_zoom. Was merged months ago. Always consult the docs.
