Lovelace only loading sometimes?
I’m really struggling to get Lovelace to load this morning. Normally it loads super quickly, but today it’s been very hit or miss. I’ve gotten it to pop up a couple times, but then I lose connection to it.
I’ve been messing with automations in Node Red, so I’m wondering if that has anything to do with it? I stopped Node Red, but I’m still having stability issues.
I’m still pretty new to HA so I’m not 100% sure what log files to check. I’ve looked at my HA logs and nothing jumps out at me as causing the problem.
Unless this is an issue, but it hasn’t been before…
“WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.”
Does anyone have an idea of what might be happening? Could this be a DuckDNS issue? My network? I’m grateful for any help.
arch: amd64
boot: true
image: homeassistant/qemux86-64-homeassistant
last_version: 0.109.6
machine: qemux86-64
port: 8123
ssl: true
version: 0.109.4
version_latest: 0.109.6
wait_boot: 600
watchdog: true
Yep, it’s DuckDNS. Going to leave this posted in case anyone else stumbles upon it.
I’ve also been experiencing the DuckDNS issues. Makes you think about another potential point of failure, although DuckDNS is a great service.
DuckDNS is amazing and I love that it’s free, but for a few bucks a year it might make sense to buy a domain. I think overall DuckDNS does pretty well, so I’ll hold off and see how things play out.
