Lovelace question
Is it possible to go back to the configuration as it was before adding the Lovelace mode to configuration.yaml?
I want to experiment with various Lovelace display options and found the default edit approach easier than the text-based option after enabling Lovelace manually.
I have removed these lines from configuration.yaml and have removed the ui-lovelace.yaml file then restarted and it still uses that mode.
lovelace:
  mode: yaml
How do I revert, please?
Restore a backup or snapshot?
Actually since you used mode yaml I think you can just take those lines out of the configuration & restart.
Cancel that question and accept my apologies, please.
I went back to it and it has now reverted. No idea why it took so long but it seems to be sorted. Thanks
Thanks, @anon34565116 - that was what I thought but it didn’t work even after a restart. And then about 5 minutes after I posted the question it suddenly worked!
Apologies for wasting your time!
