Hi I got this setup and working well, Iām using it for a news feed, which updates every few minsā¦ How can I get the rss feed (and card on the frontend) to update every 5 mins? is that at all possible?
Any ideas why the card doesnāt pick up the entries from the sensor?
sensors.yaml
- platform: feedparser
feed_url: āhttp://expressen.se/rss/nyheterā
date_format: ā%a, %b %d %I:%M %pā
inclusions:
exclusions:
Example of sensor content:
entries:
- link: >-
Fem dƶmda fƶr brutala rƄn i Gƶteborg
title: Fem dƶmda fƶr flera brutala rƄn i Gƶteborg
image: >-
https://static.cdn-expressen.se/images/a6/2e/a62eb61087c8421d9ee6753e61e4082c/16x9/[email protected] - link: āHƶgskoleprovet vĆ„r 2021 ā testa om du kan alla ordā
title: Hƶgskoleprovet vĆ„ren 2021 ā kan du orden?
image: >-
https://static.cdn-expressen.se/images/18/50/18505b7559de4100a1d54314800273c4/16x9/[email protected]
card:
type: ācustom:list-cardā
entity: sensor.rss_feed
title: Engineering Feed
feed_attribute: entries
columns:
- title: āā
type: image
add_link: link
field: image - title: Title
field: title
style: null - white-space: nowrap
- title: Description
field: description
Result:
I have an issue with this solution out of a sudden after upgrading to 2021.6.3 now.
Have not changed anything to the configuration or ui-lovelace files, also the sensor for the RSS feed is working and showing all the fields within the attributes (names unchanged as well). The list card is displayed (so also installed), title displayed but no feeds. Also tried with other sensors, but same result.
Any clue or anybody with the same issue?
I reviewed the developer tools - engineering feed entity and could see that I was no longer getting any ādescriptionsā. I since removed the following lines from the ācustom:list-cardā and now I get the images and titles successfully.
Remove
style: null
white-space: nowrap
title: Description
field: description
Thanks for your reply. I looked thru the list-card.js but have not found the lines you are mentioning. Can you give me a hint how to perform your fix?
Thx again!
What I am doing is a workaround to just get the images and titles as the descriptions seem to be missing from the attributes for the engineering feed. What I simply did was edit the card in my lovelace view to remove the descriptions.
Previous Card - No longer working
- type: custom:list-card
entity: sensor.engineering_feed
columns:
- title: āā
type: image
add_link: link
field: image
- title: Title
field: title
style:
field: description
Changed To
columns:
- title: āā
type: image
add_link: link
field: image
- title: Title
field: title
I hope the above helps to at least give you some information. But I guess this still needs to be fixed so we can get the description information back.
Thanks again. I have removed all style attributes and reduced the confi to itās bare minimum but still no result. I hope this gets fixed soon.
Thx for the support anyway.
Hello, Iām new to HA, but have installed a few cards from HACS. list-card dosenāt pull up for me, so I tried the lovelace guide of installing it manually and still no dice. Does anyone have a tip on how to get list-card installed?
btw Feedparser is installed and working according to developer tools.
Thank you!
Would like to know that as well!
Click the 3 dots menu in the top right corner of HACS, select custom repositories, add the github address for the list card and select āfrontendā as the category.
I canāt get the images to show anymore. Any ideas what is wrong:
Here is my config.yaml part:
feed_url: 'https://www.is.fi/rss/tuoreimmat.xml'
inclusions:
Here is my lovelace.ui part that i want to get to work:
title: ''
row_limit: 6
columns:
- field: image
title: ' '
type: image
add_link: link
- title: ' '
field: title
add_link: link
And this is how i can get it to work without images:
title: ''
row_limit: 6
columns:
- title: 'Uutisotsikko '
field: title
add_link: link
Any ideas how to get the pics vissible again? it used to work earlier this yearā¦
Iām getting an error (again) and no sensors are created/filled:
File "/usr/local/lib/python3.9/site-packages/dateutil/parser/_parser.py", line 655, in parse
ret = self._build_naive(res, default)
File "/usr/local/lib/python3.9/site-packages/dateutil/parser/_parser.py", line 1241, in _build_naive
naive = default.replace(**repl)
ValueError: second must be in 0..59
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 431, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 633, in async_device_update
await task
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/config/custom_components/feedparser/sensor.py", line 110, in update
value = parser.parse(value)
File "/usr/local/lib/python3.9/site-packages/dateutil/parser/_parser.py", line 1374, in parse
return DEFAULTPARSER.parse(timestr, **kwargs)
File "/usr/local/lib/python3.9/site-packages/dateutil/parser/_parser.py", line 657, in parse
six.raise_from(ParserError(e.args[0] + ": %s", timestr), e)
File "<string>", line 3, in raise_from
dateutil.parser._parser.ParserError: second must be in 0..59: 2021-09-08T12:15:1631099700Z
Iāve got the same error some days ago, then an update of feedparser arrived and it was working again for a few days. All of a sudden it stopped working
Iām on HA 2021.9.4 and feedparser 0.1.7. Any ideas?
Canāt get the image out of this RSS feed. What should i use to get the image (tried already with the image parameter but no luck). Titles only works perfect.
The following is the response after the feedparser.
entries:
- title: >-
Afgelopen week bijna 40 procent meer positieve coronatests, ook fors meer
opnames
title_detail:
type: text/plain
language: null
base: https://www.nu.nl/rss/Algemeen
value: >-
meer opnames
links:
- rel: alternate
type: text/html
href: >-
https://www.nu.nl/coronavirus/6169374/afgelopen-week-bijna-40-procent-meer-positieve-coronatests-ook-fors-meer-opnames.html
- length: '0'
type: image/jpeg
href: >-
https://media.nu.nl/m/qlbxndiazeci_sqr256.jpg/afgelopen-week-bijna-40-procent-meer-positieve-coronatests-ook-fors-meer-opnames.jpg
rel: enclosure
- href: >-
https://nu.nl/coronavirus/6169375/grootste-aantal-coronapatienten-opgenomen-op-verpleegafdelingen-sinds-december.html
rel: related
title: >-
Grootste aantal coronapatiƫnten opgenomen op verpleegafdelingen sinds
december
type: text/html
- href: >-
https://nu.nl/coronavirus/6169359/ziekenhuizen-bieden-weer-minder-zorg-aan-door-aanhoudende-coronadrukte.html
rel: related
title: Ziekenhuizen bieden weer minder zorg aan door aanhoudende coronadrukte
type: text/html
- href: >-
https://nu.nl/coronavirus/6169338/voor-het-eerst-in-deze-coronagolf-wordt-coronapatient-naar-duitsland-verplaatst.html
rel: related
title: >-
Voor het eerst in deze coronagolf wordt coronapatiƫnt naar Duitsland
verplaatst
type: text/html
link: >-
summary: >-
De afgelopen week testten opnieuw een recordaantal mensen positief op het
coronavirus. In de weekupdate meldt het RIVM 153.957 positieve tests, een
stijging van bijna 40 procent ten opzichte van een week eerder. Ook het
aantal ziekenhuisopnames blijkt fors te zijn gestegen.
summary_detail:
type: text/html
language: null
value: >-
het coronavirus. In de weekupdate meldt het RIVM 153.957 positieve
tests, een stijging van bijna 40 procent ten opzichte van een week
eerder. Ook het aantal ziekenhuisopnames blijkt fors te zijn gestegen.
published: Tue, Nov 23 03:07 PM
guidislink: false
tags:
- term: Algemeen
scheme: null
label: null
- term: Coronavirus
scheme: null
label: null
authors:
- name: NU.nl
author: NU.nl
author_detail:
rights: 'copyright photo: ANP'
rights_detail:
type: text/plain
language: null
value: 'copyright photo: ANP'
friendly_name: Engineering Feed
icon: mdi:rss
I made a separate custom component to handle enclosure tagsā¦
"""Feedparser custom sensor"""
from __future__ import annotations
import asyncio
import re
from datetime import timedelta
import homeassistant.helpers.config_validation as cv
import voluptuous as vol
from dateutil import parser
from homeassistant.components.sensor import PLATFORM_SCHEMA, SensorEntity
from homeassistant.const import CONF_NAME
import homeassistant.util.dt as dt
import feedparser
import requests
__version__ = "0.0.1"
REQUIREMENTS = ["feedparser"]
CONF_FEED_URL = "feed_url"
CONF_DATE_FORMAT = "date_format"
CONF_INCLUSIONS = "inclusions"
CONF_EXCLUSIONS = "exclusions"
CONF_SHOW_TOPN = "show_topn"
CONF_LOCAL_TIME = 'local_time'
DEFAULT_SCAN_INTERVAL = timedelta(hours=1)
COMPONENT_REPO = "https://github.com/custom-components/sensor.feedparser/"
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_NAME): cv.string,
vol.Required(CONF_FEED_URL): cv.string,
vol.Required(CONF_DATE_FORMAT, default="%a, %b %d %I:%M %p"): cv.string,
vol.Optional(CONF_SHOW_TOPN, default=9999): cv.positive_int,
vol.Optional(CONF_INCLUSIONS, default=[]): vol.All(cv.ensure_list, [cv.string]),
vol.Optional(CONF_EXCLUSIONS, default=[]): vol.All(cv.ensure_list, [cv.string]),
vol.Optional(CONF_LOCAL_TIME, default=False): cv.boolean,
@asyncio.coroutine
def async_setup_platform(hass, config, async_add_devices, discovery_info=None):
async_add_devices(
FeedParserCustomSensor(
feed=config[CONF_FEED_URL],
name=config[CONF_NAME],
date_format=config[CONF_DATE_FORMAT],
local_time=config[CONF_LOCAL_TIME],
show_topn=config[CONF_SHOW_TOPN],
inclusions=config[CONF_INCLUSIONS],
exclusions=config[CONF_EXCLUSIONS],
True,
class FeedParserCustomSensor(SensorEntity):
def __init__(
self,
feed: str,
date_format: str,
show_topn: str,
local_time: bool,
exclusions: str,
inclusions: str,
) -> None:
self._feed = feed
self._attr_name = name
self._attr_icon = "mdi:rss"
self._date_format = date_format
self._local_time = local_time
self._show_topn = show_topn
self._inclusions = inclusions
self._exclusions = exclusions
self._attr_state = None
self._entries = []
def update(self):
r = requests.get(self._feed).content
parsed_feed = feedparser.parse(r)
if not parsed_feed:
return False
else:
self._attr_state = (
self._show_topn
if len(parsed_feed.entries) > self._show_topn
else len(parsed_feed.entries)
self._entries = []
for entry in parsed_feed.entries[: self._attr_state]:
entry_value = {}
for key, value in entry.items():
if (
(self._inclusions and key not in self._inclusions)
or ("parsed" in key)
or (key in self._exclusions)
continue
if key in ["published", "updated", "created", "expired"]:
if self._local_time:
value = dt.as_local(value)
value = value.strftime(self._date_format)
entry_value[key] = value
images = []
if "image" in self._inclusions and "image" not in entry_value.keys():
if "summary" in entry.keys():
images = re.findall(
r"<img.+?src=\"(.+?)\".+?>", entry["summary"]
if images:
entry_value["image"] = images[0]
if "enclosure" in self._inclusions and "enclosure" not in entry_value.keys():
if entry.enclosures:
images.append(str(entry.enclosures[0].href))
if images:
else:
entry_value[
"image"
] = "https://image.shutterstock.com/image-vector/no-image-vector-isolated-on-600w-1481369594.jpg"
self._entries.append(entry_value)
@property
def device_state_attributes(self):
return {"entries": self._entries}
Nice!!
How do i integrate this in home assistant?
The easiest options would be to edit sensor.py in feedparser or copy/paste the feedparser folder then rename to create a separate component. In that case you will need to also edit manifest.json.
"domain": "feedparser_custom",
"name": "Feedparser custom",
"version": "0.0.1",
"documentation": "",
"dependencies": [],
"codeowners": ["@wetzel402"],
"requirements": ["feedparser==6.0.8", "requests==2.26.0"]
Thanks for the help.
I tried your code and suggestions , but still no image in the feed parser sensor.
You should load up the URL in your web browser and make sure their is an image in the enclosure tag.
It is an JPG image (see example). The URL is in the links part of the feed parser sensor.
entries:
- title: >-
Quarantaineplicht voor Nederlanders in Oostenrijk, behalve na booster en
PCR-test
title_detail:
type: text/plain
language: null
value: >-
PCR-test
links:
- rel: alternate
type: text/html
href: >-
https://www.nu.nl/buitenland/6174480/quarantaineplicht-voor-nederlanders-in-oostenrijk-behalve-na-booster-en-pcr-test.html
- length: '0'
type: image/jpeg
href: >-
https://media.nu.nl/m/m1mxxp9aqakn_sqr256.jpg/quarantaineplicht-voor-nederlanders-in-oostenrijk-behalve-na-booster-en-pcr-test.jpg
rel: enclosure
link: >-
summary: >-
Oostenrijk heeft Nederland, Groot-Brittanniƫ, Noorwegen en Denemarken
aangemerkt als gebieden waar de omikronvariant van het coronavirus heerst.
Dat betekent dat reizigers vanuit deze landen vanaf zaterdag verplicht in
quarantaine moeten na aankomst, tenzij ze een boosterprik hebben gehad en
een negatieve PCR-test kunnen tonen. Dat meldde de Oostenrijkse overheid
woensdag op een persconferentie.
