Lovelace: Swiper card
I think it cant works if the swipe card is inclued in another custom card. I removed all cards except this swipe card and still does not work.
type: 'custom:layout-card'
layout: grid
gridrows: 130px 130px 165px 59px 59px
gridcols: 65px 65px 300px 300px 230px
cards:
  - type: 'custom:swipe-card'
    card_width: 230px
    start_card: 2
    parameters:
      effect: coverflow
      grabCursor: true
      centeredSlides: true
      slidesPerView: auto
      coverflowEffect:
        rotate: 50
        stretch: 0
        depth: 80
        modifier: 1
        slideShadows: true
      pagination:
        type: bullets
    cards:
      - type: 'custom:mini-graph-card'
        line_width: 5
        entities:
          - sensor.speedtest_upload
        font_size: 40
        line_color: cyan
        show:
          header: false
          icon: 'mdi:cloud-upload'
          fill: fade
        decimals: 0
        height: 50
        hour24: true
        animate: true
        line_width: 5
        entities:
          - sensor.speedtest_download
        font_size: 40
        line_color: greenyellow
        show:
          header: false
          icon: true
          fill: fade
        decimals: 0
        height: 50
        hour24: true
        animate: true
        line_width: 5
        entities:
          - sensor.speedtest_ping
        font_size: 40
        line_color: deeppink
        show:
          header: false
          icon: true
          fill: fade
        decimals: 0
        height: 50
        hour24: true
        animate: true
    gridcol: 1/4
    gridrow: 4/6
Hi.
I want to use the swiper card as a menu for the top of my page, so select different views. Iā€™m missing a couple of elements to make this work as I would wish, and I wonder if you have any pointers?
  1. Iā€™m using coverflow, but Iā€™d like to be able to select a button regardless of whether that button is centred on the screen and jump to that page
  2. because each view is its own URL, each view has its own instance of the swiper card, which means every time i switch to the view, the swiper card resets to button 1 rather than indicating the current page. Is it possible to somehow pass the view in as a parameter? (In image, the batteries page is selected, but it still shows as ā€˜Homeā€™
    Iā€™m using a single include file for the menu)
( for my wall tablets Iā€™m removing the title and side bars)
  1. Iā€™ve tried various parameters without success, but is it possible to make the menu properly rotate? ie, so that there is no absolute left or right of the list
Thanks in advance for all help.
Iā€™m having the ā€œt.setConfig is not a functionā€ error too Matt. Did you ever get it fixed?
Nope, gave up on this card. I think itā€™s abandonware
Sorry, didnā€™t notice this.
No, still have not got it working.
Hi there. Am attempting to place an atomic-calendar-revive card inside a swiper-card but am struggling a little.
What Iā€™m trying to do is lock the calendar cardā€™s height so that it doesnā€™t take up too much space on my dashboard, and then I can scroll within the card to see all the events within a limited space. This works well using the cardā€™s own cardHeight functionality.
However, once I place the calendar card inside a swipe card, it borks the formatting and ends up looking like the attached image. Anyone have any idea what I might be doing wrong?
Yaml is as follows:
parameters:
  scrollbar: null
  hide: false
  draggable: true
  snapOnRelease: true
  autoplay:
    delay: 7000
    disableOnInteraction: false
  speed: 1000
cards:
  - type: 'custom:atomic-calendar-revive'
    enableModeChange: true
    entities:
      - entity: calendar.family
    firstDayOfWeek: 1
    maxDaysToShow: 60
    showDate: true
    showLocation: false
    showCurrentEventLine: false
    showMonth: true
    showDescription: false
    showProgressBar: false
    showWeekDay: true
    cardHeight: 100px
Has anyone done anything with a media player card?
Done what? Put a media player card inside swiper? I have. Nothing different than other cards.
Yeah put media cards in to it.
I canā€™t get them to show.
They work, all cards work inside swiper-card. I have nearly all cards you can think off, even nested cards within nested cards and conditional cards. Post your code so others can help you.
Iā€™ve read through almost all of this thread, but I couldnā€™t find the answer.
Can you set this card to auto-click the card in the middle? For instance, I have various ā€˜control typesā€™ per room, I can swipe through, but would rather trigger the conditional cards for that room+control type without a click on the centred card when I stop swiping.
If you havenā€™t found the answer here, you should check out the API this card uses (Swiper API). Itā€™s mentioned in the first post: http://idangero.us/swiper/api/
Unless someone already uses it like this, I donā€™t think youā€™ll find the answer in this thread. So in this case, you need to read the Swiper API docs and experiment with it.
Thanks, I have been through the API page but couldnā€™t find a mention of this type of option. Iā€™ll go back through it and check I didnā€™t miss anything as it seems an obvious one to have.
Perhaps you can create it with a workaround. I see in the API it supports hash options. Maybe you can tie a slide to a hash both ways. Using the hash opens the slide, but maybe you can also set it so opening the slide, it mentions the hash in the url.
Then you can create an automation with browser_mod. When the url (with hash) is open on that device, fire a call service (of the button in that slide). Itā€™ll take a lot of work if it works though setting this up per slide/hash.
anyone figure out why swiper card doesnt work with a simple entities list? Works fine with other complex types
This might be a reach, but does anyone know of a way to dynamically reorder the cards being displayed in swiper card?
Iā€™m using swiper for climate entities and Iā€™d like it to put the climate entity thatā€™s currently on, at the front. Thanks.
I have tried this and it works. Perhaps post your card config.
You can put your swipe cards in conditional cards or use the state switch. The state switch is much more flexible if your conditions are complex.
Hereā€™s a working example from my config. One hint, order the cards backwards and set your start card to the last card. It jumps to the last card when the state switches.
Swipe in custom:state-switch example
  - type: custom:state-switch
    entity: template
    template: >
      {% if is_state('binary_sensor.notification_active','on') %} notify
      {% elif is_state('binary_sensor.commute_active','on')  %} commute
      {% else %} default
      {% endif %}
    default: default
    states:
      default:
        type: custom:swipe-card
        card_width: '98%'
        start_card: 2 # start with last cards so correct card displays when switching states
        reset_after: 120
        parameters: !include /config/lovelace/lovelace_swipe_parameters.yaml
        cards:
          - !include /config/lovelace/include/card/schedule/traffic_card.yaml
          - type: vertical-stack
            cards:
              - !include /config/lovelace/include/card/weather/weather_card.yaml
              - !include /config/lovelace/include/card/general/home_feed_card.yaml
      commute:
        card_width: '98%'
        start_card: 3 # start with last cards so correct card displays when switching states
        reset_after: 120
        cards:
      notify:
        cards:
          - type: custom:swipe-card
            card_width: '98%'
            reset_after: 120
            cards:
Thanks so much for this card. Itā€™s a really great space saver.
1 question: I have a card that I want to default to the second card in the swipe list of 3 (middle card).
For most devices that I open the lovelace page on it works as expected. But for 1 device (a google nest hub max) it always defaults to the first card on a refresh, no matter what. Any idea why that might be?
yaml below for reference:
    card_width: '90%'
    start_card: 2
    parameters:
      slidesPerView: 'auto'
      spaceBetween: 20
      scrollbar:
        hide: false
      navigation:
      keyboard:
        enabled: true
        onlyInViewport: true
    cards:
I get this t.setConfig is not a function error
