Lovelace UI removing space between stack panels
Is there a setting to remove the space that appears between stacked panels. I would like this vertical stacked gui to have no spaces between the panels. See below.
Thanks, Ynot.
This should do what you want:
Thank you that works well in google on Windows. I am having trouble with it however on the iphone using the HomeAssitant app. Error says:
  • n.setConfig is not a function (In ‘n.setConfig(1)’.n.setConfig’ is undefined.
Any thoughts? Thanks in advance Ynot.
I have been looking for a solution as well. That card works great on a computer but for some reason my tablets don’t like it.
Don’t use the card myself. You might want to add your feedback to the github page.
Will do. Thanks.
Thanks to @ofekashery on github
Take a look at this: https://github.com/ciotlosm/custom-lovelace#i-get-a-error-with-nsetconfig-is-undefied-how-do-i-fix-this
javascript_version: latest in your configuration.yaml under frontend:
