mayker
(maykar (pronounced "maker" with a southern accent))
64
Radarr Component Update
Not even half a day and back with it on Radarr. I’m now using The Movie Database for images and I imagine this will help with caching issues, timer out of sync issues, and more. Thanks for bearing with me while I learn here.
There may be instances where you’ll see a movie out of order. This happens when the movie is released to theaters and homes in a very short amount of time. Working on a fix, just be aware.
There are still no consistent sources for banners for movies, so still no banner view for movies.
mayker
65
Always restart after updating any components in HA and if you’re not updating using tracker-card and/or custom-updater be sure that you’re adding to a version number at the end of your lovelace resources when you update your cards like so:
Good news - it’s working for me now! Only problem I have, is that I set the shadow box to “off”, yet it’s still showing the shadow behind the banners. I copied it from the example you listed - but putting it in single quotes seems to fix it (‘off’).
Thanks!
mayker
68
Now radarr works great and looks great in UI. However, as soon as I add the radarr sensor i get
“Timer got out of sync. Resetting” every minute. If I remove the sensor and restart that problem disappears.
No issues having sonarr sensor.
mayker
73
Do me a favor and try disabling another component or 2 that you think may use a good bit of cpu and enable radarr sensor. Let me know if you still see it.
Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 243, in async_update_ha_state
device_attr = self.device_state_attributes
File “/config/custom_components/sensor/sonarr_upcoming_media.py”, line 106, in device_state_attributes
attributes[‘banner’ + str(attribNum)] = show[‘series’][‘images’][1][‘url’]
IndexError: list index out of range
What gives?
mayker
81
Not near a computer for a bit, but I imagine there’s no banner for a show and I need to put an exception for that case. Will be fixed soon.
any news on the timer out of sync messages with radarr yet?
mayker
83
I’m just asking too much from component, it takes too long to run and causes the out of sync issues. Im currently trying to offload a good bit of the work to the card instead. Things picked up at work so development has slowed for the time being, but rest assured I’m on it.
