hey, fab blueprint, im coming from openhab and had to write this by hand over there. Anyway im trying to use
but would like this to be a sorted list, in my immature yaml understanding i thought i might just be able to add |sort, oh how naive of me, any help appreciated.
@Blacky well yes or no. I was just giving that as an example. My problem is that in general terms, hidden entities are also alerted. In the end, it is nothing to do with battery notes. If I make something hidden, I think it is expected that it will be hidden.
You have 2 entities of each battery because you are using battery notes. Of the 2 entities that are the same battery you will need to exclude one of them in Excluded Battery Sensors (Optional). This will be for every duplicate that battery notes created. Now that you excluded one of the entities it will only look at the other entity and report on one entity.
Hello, I would like to receive notifications on my TV, but when I select the option, I only see my phone. I donât see the option to select LG TV, even though it is integrated with Home Assistant.
I have excluded our mobile phones and tablet battery level entity but they still appear in the all battery devices overview list , any idea what could be wrong in my settings?
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on â</>â and paste code in there.
The overview of all battery related devices is called battery-state-card and I am not sure this belongs to your low battery blueprint. As far I am aware of I have no other battery automation running. If the battery-state-card is related to your blueprint I will sent the code you requested.
Yes. You are receiving this notification because you would of selected the + Okay Confirmation Message. If you donât want that then just select Enable Device Notification. See below.
Iâm also using Battery Notes and I have to manually exclude all these devices (30+ which takes some time). It would be nice if hidden device is not discovered by the blueprint, or if there could be an option âExclude hidden devicesâ.
Thanks for your suggestion. What you could do is add your hidden batteries to a label, then what you do is add the label and then expand it by clicking on the <> and then all your excluded batteries entities will be selected.
Thanks for the advice - I wasnât aware of the <> trick; I assumed that labels was a no-go (" NOTE - You can only use entities. Areas, devices and labels are not supported."), but this way works well.
Hello. Thank You for such a great blueprint. However i would love to know if there is a way to get the notification to show up on the dashboard in a markdown card when a low battery is detected and for the notification to disappear when all batteries are outside of the limit.
Currently you cant have a notification in a dashboard. I have asked for it but I would like HA to build their own notification platform. Here is the post if you like to read it and vote on it, click here
