Any of you using the wifi signal, status or uptime sensors? I’ve had issues with ESP chips in the past where the wifi signal that occasionally triggers is wired to the same pin used for data, which makes it trigger that pin when a wifi heartbeat signal is sent to the chip
Worth nothing that the E27 Filament Bulbs (the largest ones) emit a high pitched noise which is super annoying. Even with stock Tuya firmware these devices seem to have this issue.
Wondering if this is something to be concerned about…
The biggest problem is (when this was mine) is that when I know there is annoying sound there’s something within my brain that tells me to focus on this sound and I hear this every time and drives me completely mad
(I’m a hypersensitive person )
Filament version, haven’t seen it flicker since though. Might’ve been a temp issue.
Nevertheless that hissing sound is pretty annoying, might swap them out again for Trådfri, it was fun to experiment with.
I am just starting with HA and am collecting information to link a LSC smart Light (GU10) from the store Action to Home Assistant. Is there a start where I should begin? There is load of input but I need to start at the right point. On your comments I can conclude you are a advanced LSC smart user
Hopefully you can assist me
I am also building up the SVG floorplan file and finally I want to link LSC smart lights on the floorplan.
Do you want to share youre esp yaml file? The flashing wan’t a problem but the yaml for the GU10 bulb drives me crazy. Because i dont know which gpio pin is which option.
yes… i didnt know youre using tasmota. Ok… then i will test is some time with esphome. And otherwise i must go back to tasmota.
You can use it with all the color patterns and warm white?
