Using a “filesize” integration to get a DB file size.
When no changes in HA config occur - DB size is same (as expected).
May be reduced by a periodical “purge” - like it is visible here:
A question is about storing LTS.
LTS are kept forever.
Even if LTS is a small amount of data - it should cause increasing a DB size.
But I do not observe a change.
May be I do not see a change since I am using a sensor with a value measured in MB?
