Lumary Zigbee Light ‎L-SD6A1
I’m trying to configure / control the Lumary Recessed Zigbee Light ‎L-SD6A1.
I’m not using a hub or the Lumary app.
Powered on the light, connected it to HA via Zigbee and immediately got the on/off control button.
All is good up to this point.
How do I go about controlling brightness and hue/color temperature?
If I do the Zigbee->Reconfigure Device I get the following report which seems to indicate that HA sees those controls…
@borisw37 Did you ever find a solution to this? I have also bought the Lumary Zigbee Recessed lighting and was wondering if they connected fine without much hassle through home assistant.
No status on this?
Anyone… Anyone else try the zigbee can light from Lumary?
