Luminance entity disappearing from multiple vendors (Philips,Aqara) in automations
I’ve had something strange occur, I have both Aqara and Philips motion sensor/temperature/luminance sensors. I have a lot of automation around my house that is dependent upon the the lux/luminance condition. However, recently, all of my automation are failing to fire, as the condition is no longer there. An exact error code is something like: Conditions: Unknown entity ‘30c26ab89926989a0b52bb8a9e3222c0’. I have validated within z2mqtt that the entities are still there on the sensor themselves, but they’re no longer selectable in the drop down box within the conditions section of the automation.
Can anyone advise what’s transpired, and what the fix is?
I second this. The respective entitys have gone missing alltogether in HA
Hi, are you using Z2M and did you recently upgraded to version 2? If so, see this:
Renamed illuminance_lux to illuminance , this breaks in two ways: illuminance_lux has been removed and the value of illuminance changes. Home Assistant users might have to manually enable this sensor via Home Assistant.
Thanks @rekenaar that was absolutely the fix, I’ve become so lazy at reading the release notes because everything works so well, should have known a 2.0 release would have some breaking changes. This seems like an odd change to be honest, but it is indeed the fix. (Manually enabling the illuminance sensor on the device.) Only 15 left to go!
