I just switched from the HACS integration to the core integration (for Caseta Pro)
One thing the HACS integration had was the ability to specify devices and domain overrides, e.g. if a wall switch controls a fan, to tell it that was so, and it created the entity as fan.name instead of switch.name.
In this integration I don’t see that feature. You can go into the entity display and change domains, but that jumps through a hoop of creating a new entity (that appears some kind of background synonym entry) and hiding the original. The original is still there, however, so doing something like “Hey Google, turn on the Bedroom Ceiling Fan” has it try to affect two devices, of course both are the same.
And yes, I can take that out by excluding from sync… but …
Is there a better way, some way so as it creates entities it knows which are which domain, as opposed to these hidden/fake entries as a workaround?
It was very nice not having to telnet to the device and pull down the definition file, but being able to specify domains was a nice feature.
