Does anyone know the step values on the dimmer? I have some new LED bulbs that are brighter than I expected and I’d love to set the limit on their brightness down a few notches. I suppose an automation could do this or sorta hacking the higher end trim value on the device itself but if someone knew the steps, I could more definitively adjust the brightness from 5K down to like 3K which would be prefered. I have a favorite on the pico in the room, but it’s also controlling the two other switches we have in the bedroom covering 3 different lights.
There is a procedure listed in their documents to adjust the top and bottom end trim levels in order to properly run LED and CCFL bulbs.
https://www.lutron.com/TechnicalDocumentLibrary/0301710_Caseta_Advanced_Instructions.pdf
thanks seems like trim is the best option.
