My Lutron Caseta integration stopped working after I updated to 2020.12.7 and I’m looking for ideas on how to fix. I’m running Home Assistant Supervised on an RPi4 - with Raspberry Pi OS (Raspbian GNU / Linux 10 (buster)).
I’ve tried the following (in order) and included my configuration yaml entry and HA log output below.
- Removed Lutron Caseta integration, YAML entries and cert files; restarted HA; added YAML entries and cert files back and restarted HA.
- Performed a completely new install: new OS image (2020-12-02), new HA install, generated cert files (using a get_lutron_cert.py file downloaded on 12/17) and placed in usr/share/hassio/ssl/lutron directory and added lines below to YAML. Restarted HA.
- Followed steps that resolved the similar issue discussed here - File Path for certificates on Lutron Caseta Component
Each time my YAML entries were:
#Lutron
lutron_caseta:
- host: IP_ADDRESS
keyfile: caseta.key
certfile: caseta.crt
ca_certs: caseta-bridge.crt
The result was the same each time:
The Lutron Caseta integration showed in my integration list after restart but when I tried to configure it I received the message: Failed to import Caséta bridge configuration. Couldn’t setup bridge (host: [ip of my lutron hub]) imported from configuration.yaml. Failed to connect
The error reported in the HA log was consistent as well:
Logger: homeassistant.components.lutron_caseta.config_flow
Source: components/lutron_caseta/config_flow.py:84
Integration: Lutron Caséta (documentation, issues)
Unknown exception while checking connectivity to bridge [ip of my lutron hub]
File “/usr/src/homeassistant/homeassistant/components/lutron_caseta/config_flow.py”, line 84, in async_validate_connectable_bridge_config bridge = Smartbridge.create_tls( File “/usr/local/lib/python3.8/site-packages/pylutron_caseta/smartbridge.py”, line 106, in create_tls ssl_context.load_verify_locations(ca_certs) FileNotFoundError: [Errno 2] No such file or directory
Any help is appreciated!
