Lutron Caséta Pico 4/5 Button Remote Advanced Actions (Core Integration)
This is a Blueprint that allows you to configure custom actions for all 4/5 buttons as well as additional 4/5 actions for long presses and 2/3 additional actions for double presses for a total of 10/13 actions off of a single remote. This integration uses the Core Lutron Caséta Integration unlike many others from a while ago.
Caveat: make sure that at least one of the entities is enabled for each Pico that you want to use, otherwise it will not show up in the dropdown selector.
5 Button Remote Blueprint: Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
4 Button Remote Blueprint: Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
5 Button Remote:
blueprint:
  name: Lutron Pico 5 Button Actions
  description: |
    Different Actions on Short, Long, and Double Click button presses.
    There is no Double Click for up/down as those are slower to respond and produce bad experience.
    Make sure you have enabled at least one Pico Event Entity for each device, they are default to not enabled as of 2023.3, otherwise they won't show up as an available device in the drop down list.
  domain: automation
  input:
    pico_id:
      description: The Lutron Pico used to trigger the automations
      selector:
        device:
          model: PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)
          multiple: false
    short_click_action_on:
      name: On Button Short Click
      description: The action(s) to launch for a single short click
      default: []
      selector:
        action: {}
    short_click_action_up:
      name: Up Button Short Click
      default: []
      selector:
        action: {}
    short_click_action_stop:
      name: Middle Button Short Click
      default: []
      selector:
        action: {}
    short_click_action_down:
      name: Down Button Short Click
      default: []
      selector:
        action: {}
    short_click_action_off:
      name: Off Button Short Click
      default: []
      selector:
        action: {}
    long_click_action_on:
      name: On Button Long Click
      description: The action(s) to launch for a long click
      default: []
      selector:
        action: {}
    long_click_action_up:
      name: Up Button Long Click
      default: []
      selector:
        action: {}
    long_click_action_stop:
      name: Middle Button Long Click
      default: []
      selector:
        action: {}
    long_click_action_down:
      name: Down Button Long Click
      default: []
      selector:
        action: {}
    long_click_action_off:
      name: Off Button Long Click
      default: []
      selector:
        action: {}
    double_click_action_on:
      name: On Button Double Click
      description: The action(s) to launch for a double click
      default: []
      selector:
        action: {}
    double_click_action_stop:
      name: Middle Button Double Click
      default: []
      selector:
        action: {}
    double_click_action_off:
      name: Off Button Double Click
      default: []
      selector:
        action: {}
    delay_click:
      name: Double Click Delay
      description: The time in milliseconds used for the double click detection
      default: 250
      selector:
        number:
          min: 100
          max: 1000
          unit_of_measurement: milliseconds
          step: 1
          mode: slider
    delay_hold:
      description: The time in milliseconds used for the hold detection
      default: 1000
      selector:
        number:
          min: 1000
          max: 4000
          step: 1
          mode: slider
  - platform: device
    device_id: !input pico_id
    domain: lutron_caseta
    type: press
    subtype: 'on'
  - platform: device
    type: press
    subtype: raise
  - platform: device
    type: press
    subtype: stop
  - platform: device
    type: press
    subtype: lower
  - platform: device
    type: press
    subtype: 'off'
  - variables:
      hold_ms: !input delay_hold
      tap_ms: !input delay_click
      pico_id: "{{ trigger.event.data.device_id }}"
      button_name: "{{ trigger.event.data.button_type }}"
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: "on"
            timeout:
              milliseconds: "{{ hold_ms }}"
          - choose:
              - conditions:
                  - condition: template
                    value_template: "{{ wait.trigger == none }}"
                sequence: !input long_click_action_on
            default:
              - wait_for_trigger:
                  - platform: device
                    type: press
                    subtype: "on"
                timeout:
                  milliseconds: "{{ tap_ms }}"
              - choose:
                  - conditions:
                    sequence: !input short_click_action_on
                default: !input double_click_action_on
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: raise
            timeout:
          - choose:
              - conditions:
                sequence: !input long_click_action_up
            default: !input short_click_action_up
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: stop
            timeout:
          - choose:
              - conditions:
                sequence: !input long_click_action_stop
            default:
              - wait_for_trigger:
                  - platform: device
                    type: press
                    subtype: stop
                timeout:
              - choose:
                  - conditions:
                    sequence: !input short_click_action_stop
                default: !input double_click_action_stop
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: lower
            timeout:
          - choose:
              - conditions:
                sequence: !input long_click_action_down
            default: !input short_click_action_down
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: "off"
            timeout:
          - choose:
              - conditions:
                sequence: !input long_click_action_off
            default:
              - wait_for_trigger:
                  - platform: device
                    type: press
                    subtype: "off"
                timeout:
              - choose:
                  - conditions:
                    sequence: !input short_click_action_off
                default: !input double_click_action_off
mode: single
4 Button Remote:
blueprint:
  name: Lutron Pico 4 Button Actions
  description: |
  domain: automation
  input:
    pico_id:
      selector:
        device:
          model: PJ2-4B-GXX-X01 (Pico4ButtonZone)
          multiple: false
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    delay_click:
      default: 250
      selector:
        number:
          min: 100
          max: 1000
          step: 1
          mode: slider
    delay_hold:
      default: 1000
      selector:
        number:
          min: 1000
          max: 4000
          step: 1
          mode: slider
  - platform: device
    type: press
    subtype: 'on'
  - platform: device
    type: press
    subtype: raise
  - platform: device
    type: press
    subtype: lower
  - platform: device
    type: press
    subtype: 'off'
  - variables:
  - choose:
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: "on"
            timeout:
          - choose:
              - conditions:
            default:
              - wait_for_trigger:
                  - platform: device
                    type: press
                    subtype: "on"
                timeout:
              - choose:
                  - conditions:
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: raise
            timeout:
          - choose:
              - conditions:
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: lower
            timeout:
          - choose:
              - conditions:
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: device
                type: release
                subtype: "off"
            timeout:
          - choose:
              - conditions:
            default:
              - wait_for_trigger:
                  - platform: device
                    type: press
                    subtype: "off"
                timeout:
              - choose:
                  - conditions:
mode: single
Have been wanting something like this for a while, excellent work!
Are the new pico paddle remotes supported yet?
Awesome work but I was wondering if you can help. I have multiple Pico remote at home and half are model: PJ2-3BRL-GXX-F01 and the other half are model: PJ2-3BRL-GXX-X01… Can you add both models to the blueprint please?
Thanks Greg, this works perfect. I took the liberty to modify it for the 2-button remote too. If anyone wants it, let me know.
