Hi all,
I’m scratching my head trying to figure out what has gone wrong here. I’ve been running this setup for well over 2 years updating every time a new release is out. My install method is virtualenv, so I have everything packed up underneath my config
and i’m able to move from one venv to the next. My OS is aging (debian bullseye), so I finally decided to begin migrating my setup to a docker install instead which should still be portable. I’m using the official docker image. Everything seems to work, except my caseta integration.
From the logs, I see
homeassistant | Traceback (most recent call last):
homeassistant | File "/usr/src/homeassistant/homeassistant/config_entries.py", line 327, in async_setup
homeassistant | result = await component.async_setup_entry(hass, self)
homeassistant | File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/__init__.py", line 117, in async_setup_entry
homeassistant | bridge = Smartbridge.create_tls(
homeassistant | File "/usr/local/lib/python3.9/site-packages/pylutron_caseta/smartbridge.py", line 110, in create_tls
homeassistant | ssl_context.load_verify_locations(ca_certs)
homeassistant | FileNotFoundError: [Errno 2] No such file or directory
I have confirmed that the files are there, and the configuration has the correct paths to the files
bash-5.1# ls -al /app/support/lutron/
total 28
drwxr-xr-x 2 1001 1001 4096 Oct 29 2019 .
drwxr-xr-x 3 1001 1001 4096 Feb 6 19:50 ..
-rw-r--r-- 1 1001 1001 790 Oct 29 2019 caseta-bridge.crt
-rw-r--r-- 1 1001 1001 2149 Oct 29 2019 caseta.crt
-rw-r--r-- 1 1001 1001 1704 Oct 29 2019 caseta.key
Relevant section of the config:
lutron_caseta:
- host: 192.168.N.NN
keyfile: /app/support/lutron/caseta.key
certfile: /app/support/lutron/caseta.crt
ca_certs: /app/support/lutron/caseta-bridge.crt
Again, this has been working for a very long time in a virtualenv install under my home directory, but now that i’m moving the install to docker, this is the only thing that does not work.
Anyone got any idea what’s wrong with this?
