Lutron Cesta Not Updating in UI? - Hass.io
Hey everyone,
I just moved from Hass on Unraid (docker) to hass.io, copying my known working config over (with a few changes for breaking some items into seperate yaml files).
Everything is running and working but my Lutron Caseta lights. They show up in the UI and in my groups without issue, but always stay off regardless of the light’s state. If I turn it on, it turns on for a second and then turns off (just the UI, not the light itself. The light will stay on). Odd thing is I tell Hass to turn off all lights with a script, the light is turned off… So it is working on the back end and just not in the front end UI.
And thoughts to what it could be? If I turn my old Hass back on, same lutron settings and IP address - no problems.
Help so I can fully transfer to hass.io!
**Cross post for visibility
Thanks!
Cliff
Anything interesting in the logs?
Nothing at all - that I can see
