Lutron DbXmlInfo.xml files
Hi, in my adventure of integrating a Lutron Standalone system to HA, I’ve found myself needing to reverse engineer the DbXmlInfo.xml file that is generated by Lutron PC configuration software for RadioRA 2 systems. I need to generate one for my network by hand (and maybe with a tool later). Currently, I am working off of one file I found with a web search and I would like to examine more files to better understand the unpublished grammar they use and explore the full functionality.
I would appreciate it if anyone could reply with a copy of their DbXmlInfo.xml file. If you don’t have a copy handy, you can download it from your RadioRA 2 repeater by either fetching or browsing “http://yourRadioRA2RepeaterIP/DbXmlInfo.xml
Thank you.
Do you still need a file?
FYI I’m currently in the process of writing a real QS Standalone integration. It will (assuming I can get all the ridiculous details worked out) fully automatically discover everything on the network – it should only need an IP address, username and optional password. No XML anywhere in the pipeline :slight_smile:
