Lutron Pico Media Remote, Logitech Media Server & Soundavo
Hi folks,
I’m conceptualizing my home automation (more specifically, media library/LMS) and I need guidance.
Use case:
I have Logitech Media Server (Squeezebox) currently controllable via Home Assistant. My main use case for LMS is a local library and a few favorites (radio stations). The current capabilities with the hassio mobile app is quite limited as it pertains to browsing my library on a network drive (LAN), and I can’t figure out how to get to my favorites using hassio.
My second way to better control LMS is the mobile app iPeng. I can do it all on that app.
Audio distribution
I also have the Soundavo audio distribution system. I can control most of what I need to control with hassio or the Soundavo app.
Physical controls
I’m looking into different options to control both, LMS and Soundavo with a physical option such as the Lutron Pico remote (media remote for Sonos). I’m nearly committed with Lutron caseta/diva for light controls and fans, etc. As such, I would prefer to stay within the Lutron ecosystem.
The question is… has anybody tried the Lutron Pico remotes to control a Soundavo audio distribution system and a local music server (LMS) via the hassio / Lutron integration? Does it work? Any glitches? How many remotes did you need (I mean there is a limited number of buttons on those remotes) to control the Soundavo inputs, zone syncs, volume, bass, trebble and balance? How about LMS controls (my main use for LMS controls is volume and track/playlist selection)?
Thank you for sharing your experiences!
I’m about to purchase the Soundavo WS66i. Before I pull the trigger, I’m confused if HA (Home Assistant) can control the WS66i amplifier simply through the Ethernet port or does it have to be connected via the RS-232 cable?
My new setup:
  • Fully smart home (new house/under construction)
  • Hoping to run HA via Raspberry Pi (any other suggestions?)
  • All Kasa Smart Light switches
  • Looking to add motion sensors (undecided)
  • ReoLink security cameras
  • Confused about the audio system, since unsure of the above
Audio setup:
  • 4 x bedroom, each with TV’s and 2 pairs of in-ceiling speakers (each)
  • Soundavo WS66i??
You can control the WS66i with HA via the ethernet cable.
