Lutron Radio RA 2 Integration Issues
I have Radio RA 2 setup and it’s been working fine for months but I’m now getting a lockout from my main repeater because the ip address of my home assistant is trying to login as a username #MON for monitoring. I have it setup correctly to use lutron as login and integration as password so not sure what this monitoring login is now. Home Assistant sees the devices and controls them but it’s causing havoc with my Lutron connect bridge so I can no longer access the system via my Lutron Connect App.
