LUXORliving KNX Integration released!
Hey everyone,
I’m happy to announce that LUXORliving — my Home Assistant integration for Theben LUXORliving KNX systems — has reached its first stable release and is now submitted to the HACS Default Store.
What it does: Connects your Theben LUXORliving IP1 gateway to Home Assistant via your LXP project file. Lights, covers, climate, sensors, switches and binary sensors are discovered and created automatically — no manual YAML needed.
Supported devices: S 4/8/16 (switching), D 2/4 (dimming), J 4/8 (blinds), H 6 (heating), KNX weather stations, motion detectors, window/door contacts.
Install now via HACS (custom repository until default store approval): https://github.com/phismith91/luxorliving
Requirements: Home Assistant ≥ 2025.12 · Theben LUXORliving IP1 gateway · LXP project file
Feedback, bug reports and device compatibility reports very welcome!
hey,
first of all, thank you very much for the work. I am currently getting into HA myself and am surprised how many things actually work so easily.
I also managed to integrate Luxorliving without any problems, but I only see the switches, dimmers, and binary inputs. The blinds and heating actuators are missing.
I have tried several times and also used the current lxp file. I don’t know exactly how the assignment works, but in Theben Luxorplug I chose German as the language.
A big thank you from my side as well for your work! I was really happy to see that someone has already created an integration. :slight_smile:
Everything is running smoothly so far, but I’m also not seeing the heating and covers. Unfortunately, I haven’t had time to look at the code yet.
I’d be happy to provide the lxp file if that helps.
I also noticed that all the lights turn off once when the lxp file is being read, but that might just be my specific setup.
Best regards
